3"O2 housing w/external dump
Old Jan 10, 2004 | 01:11 AM
evoSPL's Avatar
just wondering if anyone would be interested in a 3"o2 housing w/external dump.
let me know what u guys think.
thanks
http://www.gtfabrications.com/gtf/evoo2/index.html
Old Jan 10, 2004 | 04:57 AM
memo3's Avatar
I had some bad experiences before with 02 housing downpipes generally, so I would go with stock 02 housing unless you are doing a turbo upgrade...
Old Jan 10, 2004 | 05:26 AM
03EvoVIII's Avatar
It isn't an O2 housing downpipe. It is a 3" O2 housing which you can either dump the wastegate gasses or route them back to the exhaust flow. Both versions can be used with the stock downpipe or their downpipe.
Old Jan 10, 2004 | 11:51 AM
evoSPL's Avatar
our O2 housing will only be able to mate with a 3" downpipe.
if you have someone elses DP you will have to let us know who's so we could build accordingly.
on the bad experience with your DP what was wrong with it and what company made it?
i would like to know so we can provide top quality products.
thanks
Old Jan 10, 2004 | 04:21 PM
evoSPL's Avatar
any more feed back?
Old Jan 10, 2004 | 04:31 PM
03EvoVIII's Avatar
I'm interested in the dump version.
I have a question though. If it will work with the stock downpipe, why wouldn't any aftermarket downpipe? The reason I am asking is because aftermarket downpipes bolt onto the stock O2 housing, and your o2 housing will work with the stock downpipe, so I don't see how there would be a problem. I hope you understand my question.
Thanks
Old Jan 10, 2004 | 04:47 PM
MalibuJack's Avatar
Many aftermarket downpipes don't use the stock donut, but instead fits without it.
evoSPL's Avatar
sorry there was a mis print on our page. the O2 housing will be full 3" so the DP inlet side has to be 3". the stock housing is roughly a little less than 2.25 with the DP being about 2.5. if you have an aftermarket DP that is a full 3" but but has a flat flange and a flex section built-in you will have to let us know so we can delete the extra lip that holds the 3" donut style gasket. and provide you with a standard gasket. i hope this all makes sense and i will fix the web page as soon as possible.
thanks for your reply
Old Jan 10, 2004 | 04:52 PM
03EvoVIII's Avatar
Thanks for the respones MalibuJack and evoSPL. Sounds like a greast piece but I guess I'll have to wait to get my downpipe first.
Old Jan 10, 2004 | 04:57 PM
evoSPL's Avatar
the DP's that we will be building soon will accept a 3" donut style gasket that we can provid. i will probably keep the gasketes separate since there will be tooo many variables.
the O2 housing will be fully polished as well.
we will be working on making a stainless heat shield with some sort of ceramic blanket on the inner side as well. kind of like the old WRC RALLIART stuff. kind of cool.......i hope
Old Jan 10, 2004 | 05:21 PM
evoSPL's Avatar
i forgot to mention that we will be offering this with a hi-temp ceramic coating as an option. the coating will resist temps up to about 1300 F
Old Jan 10, 2004 | 05:24 PM
03EvoVIII's Avatar
How about an option for a second 02 sensor bung for those that are running widebands?
Old Jan 10, 2004 | 05:31 PM
evoSPL's Avatar
not a problem. we have done that before for DSMs
Old Jan 10, 2004 | 05:33 PM
03EvoVIII's Avatar
Sounds like I could just call you guys when I'm ready tell you what I want and then you would make it for me. Now that is customer service!!!!
Old Jan 10, 2004 | 05:38 PM
evoSPL's Avatar
thanks 03EvoVIII! if you are interested we will be coming out with our own down pipes soon as well.
