Best Gear Ratios for Uphill & Track...
Old Nov 24, 2011 | 03:08 AM
MR. EVO MR's Avatar
I want tall gears like in a 911 GTR. 40mph in first no problem. Can the EVO do the same?
Old Nov 24, 2011 | 03:55 AM
todd6027's Avatar
Originally Posted by jameswwt
Have check and ive a W5M51-2-X6A1 with a final gear ratio 4.529.
What is the different of 4.529 vs 4.875 & 4.11???
Thanks
speeds in each gear at 7k with 17 inch wheels 215/40 tyres
RS with 4.87 (1) 36 (2) 52 (3) 70 (4) 93 (5) 123
RS with 4.11(1) 43 (2) 62 (3) 84 (4) 110 (5) 146
GSR with 4.52 (1) 39 (2) 56 (3) 78 (4) 106 (5) 143
Old Nov 24, 2011 | 04:09 AM
sparky's Avatar
Are the road speeds at these shift points calculated at 7500 RPM, Todd?
EDIT: Duh, it is too early for me yet! The RPM of the shift points is clearly stated in your post as 7000 RPM(I guess that I can't understand your "7K" shorthand)....Duh, Sparky!
Old Nov 24, 2011 | 04:25 AM
sparky's Avatar
Todd: I was under the impression that there were three available final drive ratios available for the non-USDM RS cars. I understood that there are short, medium, and long boxes available...and not only two as you have posted up for the RS boxes.
Old Nov 24, 2011 | 04:34 AM
sparky's Avatar
Is the serial number on the box visible from under the car? Can I just put it up on the lift to get a peek? Is it stamped on the box, or is there a plate, or tag, etc.?
Old Nov 24, 2011 | 04:39 AM
sparky's Avatar
According to the info that todd6027 has posted up the V RS boxes do not have a 1:1 fth gear. In the V RS box 5th is a 0.825 reduction.
Old Nov 24, 2011 | 04:51 AM
jameswwt's Avatar
You can see the codes directly below the water thermostate for Evo 4 5 6
Old Nov 24, 2011 | 04:52 AM
jameswwt's Avatar
Thanks Todd but what do you mean? Sorry for the nob question?
Old Nov 24, 2011 | 05:21 AM
sparky's Avatar
According to the two options that todd6027 has posted, I would imagine that you'll probably want the V RS box with the 4.87 final drive. The other one with the taller final drive would place 4th and fifth at almost unusable speeds(too high) under most circumstances. Of course it depends on the highest road speed that you can reach on your particular uphill course.
Old Nov 24, 2011 | 06:00 AM
todd6027's Avatar
yes there is afaik its a mix of rs gearing with gsr final drive also the 4.11 wasnt a factory option
best box for hillclimb would be the rs gearing with 4.875
other rs box
RS box other option .......(1) 45 (2) 64 (3) 86 (4) 114 (5) 151
Old Nov 24, 2011 | 06:22 AM
sparky's Avatar
According to the gear ratios posted up by todd, the RS box with the 4.875 final drive has a .825 overdrive 5th gear, which works out to a 4.02 overall in 5th. For Uphills on a 2L engine I would prefer a true 4.11 overall in 5th, maybe even a 4.24 if possible, especially if you'll be shifting it at 7500 instead of 7000. However, you can still factor in and tinker with top speed and the speeds in the intermediate gears by judiciously choosing the rolling diameter of your tires.
Old Dec 4, 2011 | 08:23 AM
jameswwt's Avatar
Great Info...
kartectuning
12
Nov 17, 2022 07:44 AM
2rbolag
29
Feb 2, 2017 02:27 AM
alpinaturbo
28
Sep 10, 2013 08:22 AM
jameswwt
16
Mar 19, 2013 09:09 PM
jameswwt
15
Apr 18, 2012 07:49 AM
