jdm 5th gears 0.825 ratio part number??
Old Dec 10, 2012 | 11:14 PM
kartectuning's Avatar
Guys
Do you happend to have the jdm 5th gear part numbers? for input and ouput gears? 0.825 ratio pls, for the 5spd evo tranny
thanks a lot for the advance
Old Dec 11, 2012 | 12:05 AM
sparky's Avatar
If you don't get the part numbers you need on here, you may wish to ask over on Lancer Register. Or maybe call one of the two major Evo tranny specialty shops here in the U.S.(Shep, or TRE).
Old Dec 11, 2012 | 12:26 PM
emailed shep, hopefully waiting for reply, jack transmission doesnt know, tre never answers the phone after he moved
Old Dec 11, 2012 | 12:55 PM
todd6027's Avatar
Md 771726 n=40 input shaft 5th
Md 771727 n=33 output shaft 5th
Rs 0.827
just for comparison
Mr 581020 n=43
Mr 581018 n=31
Gsr 0.72
Old Apr 3, 2013 | 03:39 PM
TURBO_S2K's Avatar
Anyone know where i can buy these??
Old May 5, 2020 | 07:30 AM
evoVI_PR's Avatar
Hello,
Were you ever able to find the JDM 5th gears?
Old May 5, 2020 | 03:07 PM
blackline's Avatar
5 Year Member
Originally Posted by evoVI_PR
Hello,
nope, I'm still looking for it
Old May 5, 2020 | 03:17 PM
LetsGetThisDone's Avatar
You can order it from TRE or Ross Sport
Old May 5, 2020 | 04:03 PM
german_evoVII's Avatar
Attention:
There are 2 Different 5th Gear sets available!!! ( Both the 0.825 ratio )
These are not interchangeable: It depends on the Type of your Transmission....
The 5 Speed Trans up to Evo 7 had an different input shaft with an shorter Gear Spline for the 5th Gear. These have different Part Numbers.
So you have to figure out what Input shaft is in YOUR Trans....
Look for the Trans Number :
"W5M51-2-X5B" and number 1 to 4 ( then its an Evo 7 Trans ) Needed is MD771726 and 727 (as mentioned )
"W5M51-2-X5B" and then an letter A to G is Evo 8 and up Needed is MN107625 and MR980665
But ... you never know if the Trans was maybe revised before...so it could happen that an Evo 8 Input shaft was installed in an 7 Gearbox...... so check before ordering Parts...
Old May 5, 2020 | 04:08 PM
evoVI_PR's Avatar
Mine is an Evo6, that we have owned since new so I know the input and output shafts are original.
Do you know what would be the correct part numbers for my application?
Thanks!
JCG
Old May 5, 2020 | 05:02 PM
Then it should be the MD771726 and MD771727
You can get if from Rosssport UK
https://www.rosssport.com/Brands/Mit...ed-MITMD771727
https://www.rosssport.com/Brands/Mit...ed-MITMD771726
Old Nov 16, 2022 | 12:01 PM
Ayoustin's Avatar
Bumping this. after talking with Jon at TRE about the JDM 5th he said he has had a ton of trouble finding them nowadays.
I'm not sure what part numbers he's looking at but I'm guess it's the ones mentioned earlier in the thread, MN107625 and MR980665.
I Rosssport mentions those two as compatible for the 8 but mentions two other parts numbers, 2528A017 and 2528A016 for the 9. Does anyone have experience with this? What are the differences between the 8 and 9 here?
Old Nov 17, 2022 | 07:44 AM
leetEVO's Avatar
2528A017 and 2528A016 are for EVO 9. The ratio for the EVO 9 JDM and USDM are the same @ .761. You want the Evo 8-8MR JDM 5th gear for the .825 ratio.
TURBO_S2K
Aug 7, 2014 05:47 PM
ranz
11
Nov 22, 2012 12:58 PM
Romeg6
Apr 14, 2008 03:31 PM
stupidfastlaser
Nov 23, 2004 02:47 PM
miubhi
May 26, 2004 10:59 AM
