Why is there an oily residue around the oil filler cap as if it is being forced out?
Why is there an oily residue around the oil filler cap as if it is being forced out under boost? It seems to be only around this area. Could this be blow-by? If so, it doesn't come through the port in the valve cover that I have vented to the atmosphere...the one that used to be connected to the intake tract. The car is a OEM longblock car with FP4Rs, an HTA35R on E85 running 30psi. I checked the OEM PCV valve & it seems to be in working order...only allowing vacuum though but not boost. When the car idles at operating temp it pulls about 35 cm/hg of vacuum...isn't that indicative of a healthy motor? I have NEVER had the dipstick pop out. I hope this isn't excessive blow-by.
ANYONE with ANY type of useful info, please chime in. Thanks.
The gasket around the oil cap is failing, or you have a bit too much crank case pressure. If it is pressure int he crank case, it's a good idea to take care of it in case it blows your dipstick out and makes a giant mess instead of just a little bit around the filler cap. If your PCV valve fails (leaks) it's a mad boost leak, but does it pressurize the crank case much if you have the driver's side breather port unblocked?
evole97
14
Nov 10, 2021 08:06 AM
Anubis18
May 9, 2013 07:17 PM
