what downpipe for 6262?
I have a dmp manifold with a 6262 with .82 ar 4 bolt housing and the housing outlet measures 2.5" there is a 10" long 2.5" diameter section of downpipe that comes off the turbo and then is welded to a 3" section there after. I want to use a full 3" dp from the housing on out. What are you guys using on your set up? I also have ac and ps so its a clearance issue I think.
im using a v-band 6262 and had a local trust worthy shop cut and weld a bend on my regular 3inch pipe didnt cost much either and had it tapped for my o2 sensor as well. Unless you can find bolt on pipe that you can bolt your downpipe too
WTT[Northeast]: my t3 6262 gen 2 for something smaller
gigitalon
Jan 18, 2017 04:24 PM
kartectuning
Feb 2, 2016 07:26 PM
2bar_evo
Aug 5, 2013 10:29 PM
batty200
13
Sep 1, 2012 02:08 PM
element26
46
Mar 22, 2011 06:06 PM
