water pump fail again...PLS HELP
Old Jan 5, 2012 | 04:00 AM
  #31
The-Evo's Avatar
I am having the same problem. My waterpump failed twice in one month. Once, a few weeks ago when the freeze plug blew out while I was boosting. I replace the oem water pump and it failed again this past weekend, when the weep hole leaked after a night of boosting. I've come to the conclusion that maybe my head is lifting, or maybe my head gasket is going. After the first waterpump failed, I re-torqued the head. I have L19 headstuds and Iam making close to 600hp on pump, boosting 30psi. I wont know for sure until I pull the head to make sure. But, basically something is over pressurizing my coolant system and is causing my water pump to fail.
Old Jan 5, 2012 | 06:42 AM
  #32
fre's Avatar
fre
Yea, if you warped your head re-torquing the studs isn't going to matter. If you can't think of any time your car might have overheated, you should probably be fine though. I warped my head on a hillclimb (overheated) and had to get it surfaced, but it wasn't that bad to to get it back on. Now that I left off the intake manifold bracket, it will be cake to take off now, that was the biggest PITA of removing the head.
Old Jan 5, 2012 | 06:44 AM
  #33
StreetThisEvo's Avatar
I have had 2 OEM EVO 9 water pumps go on my car. They are over $200 each. My car only has 17k miles on it.
I am going to an electric water pump for 2012. Dedenbear WP3 electric pump.
I'm tired of throwing money away.
Old Jan 5, 2012 | 07:01 AM
  #34
VR4Babe13's Avatar
Hey , I know there is a TSB regarding the waterpumps from Mitsu, (technical service bulletin. )
SOURCE: Mitsubishi Tech Talk Article April/May 2005
TITLE: Water Pump Failure
APPLIES TO: 2004-05 Lancer Evolution
SERVICE TIP:
Premature water pump failure may be due to the core plug popping out, resulting in coolant leakage. Replace the water pump (p/n MD979313). Be sure to perform the radiator cap pressure check as described in the service manual.
Old Jan 5, 2012 | 07:20 AM
  #35
hamx0r's Avatar
This has me thinking now... One month back, I installed a 1.3 bar radiator cap because the 1.1 bar radiator caps weren't holding pressure and leaking out the cap and last week before going out to race (I always check over everything on my car before doing so), I found some coolant on the back of my block near the oil pan and its pure green so its not mixing with anything. I didn't think 3 more psi would ruin my water pump...
Old Jan 5, 2012 | 09:43 AM
  #36
Anarchy99's Avatar
Three pages later I'll have to tell your your headgasket is leaking cylinder pressure into the cooling system. Probably want to step up to a Cosworth gasket.
Old Jan 5, 2012 | 12:19 PM
  #37
The-Evo's Avatar
Come to think of it, my car did overheat. Ever since then I've been having water pump issues. Maybe the head did warp?
Old Jan 5, 2012 | 05:55 PM
  #38
fre's Avatar
fre
Just pull the head off and put a flat edge across it, if it teeter totters you found your issue.
DSG Performance
EvoX 'For Sale' Suspension / Brakes / Handling
Sep 12, 2014 01:08 PM
motion3131
For Sale - Cars For Sale
22
Jan 6, 2013 10:22 AM
Darkn3s
30
Jun 1, 2010 07:14 PM
Vivid Racing
33
Aug 25, 2008 03:47 PM
