View Poll Results: Which Turbo you recommend for DD great HP on Low Boost.
FP Black BALL BEARING Turbo
58
41.73%
MAP EF4
39
28.06%
other T/3 - T/4
15
10.79%
not decided yet!!!
27
19.42%
Voters: 139. You may not vote on this poll
MAP ef4 vs. Fp Black BB Turbo....
Old Nov 29, 2011 | 04:40 PM
RickyJavi420's Avatar
Talking MAP ef4 vs. Fp Black BB Turbo....
Well Guys, I know lots of you have been thinking about the new BB FP BLACK turbo and others have talked to me about the new MAP ef4....
What are your opinions.. have any of you had a close experience with this turbo??? any?
I want to build my motor and want to know what exactly my car would need to support these type of Turbo... God Speed my friends...
Old Nov 29, 2011 | 09:02 PM
You can post any comment or opinion.....
haven't had a friend with a BB Black yet, but i ran in a FP Black one and it was 24psi and it hit 477whp... and ran smoothly... I drove on a GT40R around 600whp DD but kinda laggy. HTA 35r was fun too but i wanna keep it Daily driver and fun...
Old Nov 29, 2011 | 09:03 PM
binky's Avatar
DBB FP Black FTW
-Bink
Old Nov 29, 2011 | 09:10 PM
ChrisCarey's Avatar
I voted but I'm just a little biased
Old Nov 29, 2011 | 09:24 PM
Murf's Avatar
Does the Ef turbos need to be oiled from the filter housing too?
Old Nov 29, 2011 | 09:59 PM
17pstockcar's Avatar
I am in the same boat mate.
When map released there turbo's they looked the best (over the non BB fp Black) But now that the black is BB i dont think you can beat it in a stock like turbo.
But with Davids new testing is showing what the Hta 3076 can do this is a very viable option aswell.
Then you also have the new borgwarner turbo's that are shipping and more results should be comming in b4 xmas.
Im glad i am leaving my turbo as the last part of my built and have lots of time to wait.
Old Nov 29, 2011 | 11:41 PM
What type of engine setup your running?
I only run Kelford 272 cams with beehive and the other is ecuflash, full 3 exhaust, i/c pipes, and fuel pump... I wanna make sure it stays daily driver bc now that I'm looking for a good build I'm in between a lot of parts. pistons wiseco hd to the 8.5.1 or 9.0.1. .. not planning on pushing more than 35psi ....Eagle rods.. manley bearings, any suggestions... the car till this days stock turbo hit 369whp 26psi on mustang dyno before cams. haven't gone to tune yet.
I had a black for a while and sold it and it was kinda in the way it always wanted to overspool...
surging as you call it... t/3-t/4 for daily driver I've heard is not that good.. haven't found no video of the ef4 on a evo...
Old Nov 30, 2011 | 08:07 AM
ChrisCarey's Avatar
The EF3 and EF4 do include an oil feedline kit from the housing, yes.
Old Nov 30, 2011 | 08:24 AM
CurseDSM's Avatar
My question is why do you want to go with a larger turbo with low boost? Your gonna be a little laggy being larger wheels and the car wont be as fun if your only running say stock boost levels? Being I have the EF4 I would say none of them if its restricted to low boost.
Old Nov 30, 2011 | 08:37 AM
nollij's Avatar
I doubt I will get into the bigger turbos until I build the engine. When I do, I will probably go with EF4 as I can use my stock turbo as a core. The extra reliability of the BB is offset by the additional cost. You can probably get few rebuilds in before the cost is made up.
As for the difference in spool and flow? Well, we just need a bit more testing to see what people are coming up with to see a relative performance level.
Old Nov 30, 2011 | 08:40 AM
Kracka's Avatar
I'm really liking the results from MAP's EF-series turbos, I'm very happy with my EF2.
Old Nov 30, 2011 | 01:11 PM
Wink
Well i was probably thinking on running 25psi to 32psi not more than that.... Down here in PR haven't ran into somebody on a Ef4 all I've seen are FP Blacks.. non ball bearing. I just want to keep a fun daily driver with mean horsepower under the hood... Goals are 500-600whp ... My motor is around 100,000 miles on it. Haven't ever done nothing to it only kelford cams and beehive springs and retainers...
Any others suggestions... feel free to comment...
Thanks for the imput...
Old Nov 30, 2011 | 01:12 PM
Exclamation
Looking at your sig.. you say you have stock pistons and rods and bearings??? how much millage does your car have?? I'm kinda looking for those numbers...
Old Nov 30, 2011 | 01:15 PM
CurseDSM's Avatar
25 to 32 lbs of boost really isn't low hahah. I mean I guess if you consider what the turbo can handle maybe. Yes my short block is completely untouched and I just turned 60k miles
Old Nov 30, 2011 | 04:21 PM
Exclamation
How much boost your running on that EF4????
544whp its a pretty good number... and what bushur stages you have?? i kinda didn't understand it..
I just hit the 100,000 miles on mine and its first ecuflash and tune and raise of boost was around 95,000k miles. So my car hasn't been abused on boost that much. most I've pulled is 28psi dropping to 24. Ive heard my transmission 6speed doesn't last much over 400whp..
i was planning on taking it to sheppard and reenforcing the full 6 speed.. don't want to lose the drivability of the 6speed gearbox
