Help
Old Dec 1, 2011 | 08:11 PM
phi79's Avatar
Help
I'm installing turbo 9 to my evo 8, I forgot where the line go from the waste gate to, I have installed the manually boost control but forgot where is the other end go, forgive my noobness. Try have search but couldn't find anything, picture will help me a lot.
Thanks
Old Dec 1, 2011 | 08:58 PM
Murf's Avatar
I think and if I'm wrong PLEASE someone correct me. ( I run a ebc). The nipple on the turbo should be connected to the inlet port on your controller. Should be marked with an arrow of something.
Old Dec 1, 2011 | 09:06 PM
phi79's Avatar
Yes the arrow go to the waste gate how about the other end?
Old Dec 1, 2011 | 09:08 PM
sparky's Avatar
Originally Posted by phi79
I'm installing turbo 9 to my evo 8, I forgot where the line go from the waste gate to, I have installed the manually boost control but forgot where is the other end go.....
There should be two ports on your MBC. One port is in a straight line with your MBC's boost control knob(bottom port). The second port is at a right angle with respect to the boost control knob(side port).
1) The bottom port on the MBC is the boost reference. This port you should connect to the nipple on the turbo's compressor discharge pipe(aka J-Pipe).
2) The side port on your MBC should get connected to the nipple on the waste gate actuator.
Old Dec 1, 2011 | 09:11 PM
Murf's Avatar
YES what sparky posted!!!!
Old Dec 1, 2011 | 09:33 PM
phi79's Avatar
J pipe yes that is I remember now, thanks
