Im stumped! Is it the tune?
Old Dec 5, 2011 | 07:52 AM
  #31
BOOSTINAT30PSI's Avatar
Thanks freddie... Thanks for the help... And thanks everyone for their input and help also!
Old Dec 5, 2011 | 08:52 AM
  #32
JohnBradley's Avatar
Sounds dead lean to me.
aaron
Old Dec 5, 2011 | 10:09 AM
  #33
So not enough fuel?
Old Dec 5, 2011 | 10:17 AM
  #34
Spec-Ops1's Avatar
I can't see the videos at work... If Aaron says lean I would listen to what he has to say...
Old Dec 5, 2011 | 11:22 AM
  #35
Originally Posted by BOOSTINAT30PSI
So not enough fuel?
Correct .
Old Dec 5, 2011 | 02:30 PM
  #36
Hopefully ill have the new maps tonight... And it works. Hopefully the injector issue is solved.
Ill still check out the biss screw
Old Dec 5, 2011 | 03:54 PM
  #37
bbyevo8u's Avatar
do yourself a favor.. take a small/stubby screwdriver, have one guy starting the car and someone else back the biss screw out a good 4 5 turns and see if that starts to help the issue!
the biss screw is located at the top of the throttle body and it doesnt take much to turn
Old Dec 5, 2011 | 03:56 PM
  #38
Bby... I will be sure to do it! Lol i know youve been telling me to do it for days now.. Lol
Old Dec 5, 2011 | 04:09 PM
  #39
tscompusa's Avatar
if its stalling and breaking up like that as you're giving it throttle its not the biss. its injector related most likely.. sounds like the latency is way off among other things.
depending where you got the injectors they might be bad / clogged as well.
Old Dec 5, 2011 | 04:14 PM
  #40
Well they were brand new rc 1200's... So id hope they arent bad.
Old Dec 5, 2011 | 04:31 PM
  #41
milruner's Avatar
what fuel are you running in your car? could be a wrong map for fuel, like a E85 cold start problem. just a thought.
MIKE
  #42
This was a 93 octane basemap..
Old Dec 5, 2011 | 04:35 PM
  #43
silver9mr's Avatar
has the problem been fixed yet?
i had a similar problem and mine was caused by my Omni 4bar sensor not having the correct setting in ecuflash, if you have a 4bar sensor check that out.
Old Dec 5, 2011 | 04:56 PM
  #44
i havent been by the vehicle since yesterday. i probably will get to the car tomorrow night. im very anxious to find out the issue!
Old Dec 5, 2011 | 07:36 PM
  #45
batty200's Avatar
I have had a very similar issue myself with the omni 4 bar. Some cars it just works fine. Some it doesnt run at all. Some same tune had no effect between stock and 4bar. Some the car wouldnt run at all.
