Boost my problem
Old Dec 9, 2011 | 09:17 PM
phi79's Avatar
Boost my problem
Hi
I just finish install the turbo 9 to my evo 8, did a couple full and it hit 25psi even with my boost controller all the way close. The turbo 9 came with the 25psi forge waste gate, could it be the problem?
Old Dec 9, 2011 | 09:24 PM
3K's Avatar
3K
It is exactly your problem.
Old Dec 9, 2011 | 09:26 PM
sparky's Avatar
Originally Posted by phi79
Hi
I am not up to speed on the Forge Racing actuators. Are you sure that it isn't a Forced Performance 25 PSI actuator?
At any rate you can try adjusting the length of the actuator rod. So that it just slides freely on and off of the flapper valve pivot arm's peg. Do you know what I am talking about or not?
Old Dec 9, 2011 | 09:28 PM
phi79's Avatar
Thanks
Old Dec 9, 2011 | 09:31 PM
phi79's Avatar
Yes it have a forge waste gate 25 psi, before I install the turbo 9, my evo 8 hold steady 19psi.
Old Dec 9, 2011 | 09:33 PM
phi79's Avatar
So if I want to keep my boost around 21 psi I should go back to the stock waste gate?
Old Dec 10, 2011 | 05:05 AM
catman78's Avatar
yes, you need to go back to stock. actuator s/b 1/2 hole stretch on to wg actuator pin.
scott08X
Sep 20, 2016 04:51 PM
DSMpsi
10
Apr 7, 2012 09:24 PM
TonyG
12
Feb 21, 2009 06:11 PM
warp9
21
Sep 23, 2005 10:47 AM
JohnathanKong
25
Apr 28, 2005 07:57 AM
