BUTTER in my engine bay? ? ? please help
Old Dec 14, 2011 | 11:39 AM
  #46
evo 9 guy's Avatar
Originally Posted by badev0
Happened to my friends car as well. It came out the valve cover and looked like diarrhea....
I would prefer the butter analogy, thank you...
Old Dec 14, 2011 | 12:33 PM
  #47
Liqquid's Avatar
woah what was the dew bottle for? it looks full! I take it that overflowed?
Old Dec 14, 2011 | 12:42 PM
  #48
4bangn's Avatar
Originally Posted by igo4bmx
I can't believe thats not butter
Old Dec 14, 2011 | 01:11 PM
  #49
badev0's Avatar
Yeah, something happened while he was going down the 1/4 strip.. lol.
Old Dec 14, 2011 | 08:14 PM
  #50
barneyb's Avatar
Originally Posted by Ramonski
I actually noticed some play in the pass side axle. I can move it a little bit side to side so that could be it. I pushed it in as much as I could into the tcase and maybe that's what stopped the leak.
As the wheels are driven over bumps in the road and go up and down the axle has to get longer and shorter. The joint next to the transfer case is there to allow this movement. On the work bench it can be moved in and out several inches. So, sideways play is normal.
Old Dec 15, 2011 | 07:12 AM
  #51
Acree's Avatar
Originally Posted by tscompusa
definitely the axle boot..
I concur with just about everyone else in the thread. I don't believe it's an oil mixture due to the viscosity. It's very thick like grease.
When I was installing my motor, I ripped one my axle boots reinstalling my half shafts. It looked identical to your photos. I would take the car to someone with a lift so you can do a thorough inspection and slowly turn the wheels to inspect the entire circumference of each boot.
-Acree
Old Dec 15, 2011 | 07:21 AM
  #52
Ramonski's Avatar
Well once again I checked it and there's NO buttery substance anywhere. I'm going to take it to the auto shop on the base I work at and check all the boots out thoroughly. I will report back.
Old Jan 23, 2012 | 06:09 PM
  #53
suby2evo's Avatar
UPDATE PLEASE this just happened to me today!!!! also did you have any work prior to this happening?
Old Jan 23, 2012 | 06:28 PM
  #54
Graphic's Avatar
Pull your radiator cap off and check there.
Pull off your oil cap and check for creamy substance.
Pull your dipstick and check for similar substance.
Actually jack your car up and check the inner and outer CV boot on both sides. Turn your wheels both directions and run your hand round all the grooves in the cv boots inner and outer.
(I can't see pictures anymore they're expired. Use imageshack.us)
If you know for sure it's not your cv's:
Coolant pressure test your car. Should stay at 15psi.
Compression test your car. (Dont forget to pull the fuel pump fuse and fuel pump relay)
Lastly check around your diff and transmission. Does your car drive funny?
Old Jan 23, 2012 | 07:31 PM
  #55
dastallion951's Avatar
i would ask if uve been to the bar recently maybe carried a drunk friend out left him unattended, and he threw up under your hood without telling you haha...jk but on the real looks like axle grease like many of people have posted prior.
Albert Ngo
09+ Ralliart Show and Shine
Aug 11, 2014 05:45 PM
Foxmaster
Nov 24, 2012 03:14 PM
Eric06
For Sale - Part Outs
Sep 29, 2010 02:48 PM
david@maxum-tec
Aug 1, 2007 03:52 PM
kreionic
May 17, 2007 06:36 AM
