272/272 Camshafts
Old Dec 14, 2011 | 11:53 PM
4g64t_dohc's Avatar
272/272 Camshafts
I am currently in the middle of my build (3g eclipse w/evo 8 head + garrett gt35r)
i finally purchased my camshafts, valves, valve springs and retainers from.............................. Brian Crower, i was UNaware they weren't a good, reliable company. i spent $450 on the 272/272 cams and around 400 for the valve/valve springs and retainers.
i talked to one of my buddies at horsepowerfreaks and he'll return everything as long as i'm just exchanging it for something else(no restocking fee). so with that being said. what IS a reliable camshaft company? i've done all the research i can on this and pretty much it comes down to Cosworth, Kleford, HKS, and GSC. money is no issue for this build i just want everything top notch and also reliable, this is going to be a Daily Driver < possibly. but at least a every weekend on the street; car. i'm going with the 272/272 set up but i can't seem to find which Camshaft manufacture is better out of the ones listed. also as for springs and retainers, i was going to go with Bee-mads?.. from what i hear they are top of the line. can someone please help me out with this? My build is at a stand still now because i realized i f*cked up buying BC.
Thanks,
Much appreciated!
Old Dec 14, 2011 | 11:57 PM
Heisman80's Avatar
Id go with the GSC S2s (they are slightly bigger - 274s) or Kelford 272s! By far the best cams i have seen in my friends car, my personal car and just on the threads - never here but good things about either.
Old Dec 15, 2011 | 12:28 AM
AWDBus's Avatar
There is a cam test floating around on here. You could look at the dyno graphs and see which would be better for your needs.
I have always been a fan of the Kigglys beehive. Super smart guy and runs what he builds.
Old Dec 15, 2011 | 12:41 AM
4g64t_dohc's Avatar
are the kiggley beehives the same as the Bee-mads??l
http://www.ffwdconnection.com/valvesprings.shtml
and okay thanks for the info i'll go with the Kelford 272's then.
so i'm guessing it's true BC is junk?
btw i am keeping the bc stainless steel intake/exhaust Valves, just because valves are valves, stainless steel is the best you can really get (standard size, not oversized) but i figured i'd actually buy "real" camshafts/springs/retainers!
i feel like such a dumb *** that i went and spent $900 on bc stuff, i was just in a hurry to get this build together, but i've realized it's going to take alot longer than i thought.
Old Dec 15, 2011 | 05:25 AM
Spec-Ops1's Avatar
GSC S2s, and Buschur BF 272s are the 2 cam choices I would recommend. As for valve springs, you can't go wrong with the Kiggly's! Some other good choices would be the GSC beehives, or a set of Supertechs...
Old Dec 15, 2011 | 05:52 AM
boostedtres's Avatar
need way more information before we can recommend a cam for you. build, engine specs, displacement, track/street? DD ? most importantly, intended usage and future goals for the car?
overall, unless you are going dyno queen or drag car, the S2's will be more than enough cam for anything from stock to hta3596. Dont know much about the BF but the reviews look pretty solid. STM has some cams that are sweet you may want to check out. Kelfords are good, pretty mild 272 so not hard on your valvetrain but make good mid range power and dont drop off too much.
lots of options, just need to decide which is best for your usage.
for the record, i still have stock turbo, gsc S2s, springs/retainers/seats. idle is great, very minimal loss in low end power, and big pick up in power up top. turbo dies out, cams want to keep pulling. very happy with my purchase, would choose the same cam if i did it over again.
Old Dec 15, 2011 | 01:51 PM
4g64t_dohc's Avatar
okay well here's everything on my list (some stuff i already have, some stuff i have yet to purchase)
Wiseco custom 9:1 compression pistons (evo 8 head swap on 2.4l eclipse gives you a 9.8:1 compression ratio) so i had to get custom made pistons that will GIVE me a 9:1 with the evo 8 head specs with my 4g64 block specs.
K1 rods
K1 Crankshaft
evo 8 cylinder head
? camshafts
? valve springs + retainers
v5 Magnus intake manifold
ETS turbo manifold (38mm wg v-band flange)
Aem EMS series 2 (evo 8)
Garrett gtx3582r (.82ar)
Clutch Masters stage 4 six-puck
HKS Evc-s boost controller
HKS ssqv4 BOV
Custom 3" downpipe
AMS fuel pressure regulator
Treadstone TR10 intercooler (34x10.5x3.5)
Tial 38mm WG
Mishimoto Radiator
AMS fuel rail
STM test pipe
Buschur Racing Dual pump hanger
2 Walbro 255's
2 Proform 10" 1300cfm fans (push-type)
FIC 1150cc high impediance injectors
Spark Tech CDI coil on plug set-up ($1,200)
Aem water/meth injection kit
??? 65mm thottle body (don't know what brand to buy!)
DC sport front and rear struts
Glowshift wideband air/fuel, oil pressure and boost gauges
Glowshift triple gauge pillar pod
Performance Mods Already on car:
3" Invidia N1 catback
Megan Racing Short Shifter
Race Rebuilt Tranz + Quaife Diff
AGX and Eibach pro-kit (3.25" drop) & stiffened springs.
The overall goal for this build is around 600-650whp
and for the most part; a daily driver or at least weekend fun car.
as for the 65mm throttle body for the evo 8 i have no clue, i know godspeed is junk, they're a replica of Boomba. however boomba doesn't offer a 65mm TB only a 75mm which is too big.
4g64 specs
Stroke 100mm
Bore 86 1/2mm
Gasket Thickness .042mm
Deck Clearance 0
Combustion Chamber 43cc
Compression Ratio 9:1
walker992
10
May 10, 2016 07:04 AM
David Buschur
18
Mar 17, 2012 10:32 PM
l EVO n
26
Mar 25, 2009 12:01 PM
rugarip
11
Apr 21, 2006 12:21 PM
fareastkorean
45
Sep 10, 2005 04:01 PM
