Transmission question
Old Dec 16, 2011 | 06:38 AM
asoom90's Avatar
Veteran: Army
Okay I'm have a question about my 06 evo 9 mr. When I put it on first and start driving the car starts to shake really hard like there something wrong with the tranny. My idea was I'm starting to get a bad tranny but not sure and some people I ask say transfer case is bad and some say fluid flush time. Please let me know what you think might e the case would like to get it fix ASAP before it gets any worst thanks
Old Dec 18, 2011 | 09:56 PM
barneyb's Avatar
I'd say probably clutch chatter. Does it do anything other than shaking when you start moving - any knocking or other unusual noises?
However, it wouldn't hurt to crawl under and establish that you have the proper oil level (up to the fill hole) in both the transmission and transfer case. There is no better way to completely ruin a gear case than to run it without oil.
Old Dec 19, 2011 | 05:45 AM
asoom90's Avatar
Veteran: Army
Only noise I hear is a little wine but it can be the motor and no knock or anything like that and after letting off the gas and putting it on nurtual at high speed the rpm just rev for a couple second till it goes back down to idel. And I'll defiantly check out the oil to see Thanks
Old Dec 19, 2011 | 02:32 PM
barneyb's Avatar
Even the stock clutch likes a quick engagement and will chatter if given the chance. So, the trick is to get the clutch engaged without shocking the drivetrain but otherwise get off the pedal. That's how people go 100K on the stocker.
