Civic Mishimoto or 53mm Civic Koyo Half Rad
http://www.streettunedmotorsports.co...diator_kit.htm
IMO this is perfect Ive used it for 2 years been on road trips and also know of at least 7 other friends using this set up.
This is what you speak of 275-285 dollars shipped.
http://www.ebay.com/itm/Koyo-Drag-Ra...item3cbea96e64
From what I found on the specs: http://www.frsport.com/Koyo-HH032412...9_p_18210.html
Features:
Koyo Hyper Series 48mm Core Technology
Reduced size and weight
Exclusive brushed aluminum finish
Nocolok-R Brazing
Precise Tube and Fin alignment
Billet aluminum filler neck
1/8 NPT Accessory Fitting and threaded plug
Billet aluminum drain plug
I dont know what "Hyper" core technology is, but I am assuming its not Dual Core radiator. And if that is true then probably the $60 "Honda" ebay special dual core radiator may be better than this.
Any thoughts....?
Just make sure the radiator you choose has dual core and 2 rows. If you do then you won't have any overheating issues as I had a similar setup in stop n go traffic in triple digit temps and zero problems. You don't need an expensive $300+ kit or fancy $250 "hyper" radiator...
Just get the $60 one, buy a straight hose from autozone that is the same diameter as what yours is now, fab up some brackets, and put your fan on and never look back. Then you can enjoy working on your exhaust/turbo areas without damaging the fins or your knuckles
Here's what mine looked like:
Any thoughts....?
Any thoughts....?
