4g64 into Evo 8, parts?
Old Dec 18, 2011 | 01:00 PM
Jabu's Avatar
Question 4g64 into Evo 8, parts?
I have a complete 4g64 and 4g63 the 2.0 has a cracked block
I am going to swap the head and turbo over onto the 4g64 button everything up and then pull it out and build it up.
My question is what parts do i need to put onto the 64 from the 63?
I've found a few lists but they're all for evo head swaps into the eclipse' and was wondering if/how different the swap would be.
Thanks guys,
Jabu
I found this
Evo 8 Head Swap Parts List
Model Part Name Part Number Qty
Eclipse 2.4L Head Gasket MD332035 1
Eclipse 2.4L Timing Belt Pulley MD156604 1
Eclipse 2.4L Timing Belt Tensioner MD308086 1
Eclipse 2.4L Timing Belt Tensioner Pulley MD182537 1
Evo 8 Adjustable Cam Gear 1
Evo 8 Cam Gear Bolt MF140285 2
Evo 8 Cam Gears MD322223 1
Evo 8 Camshaft Seals MD153103 2
Evo 8 Camshaft Sensor Housing MD344722 1
Evo 8 Camshaft Sensor Housing Cover MD329502 1
Evo 8 Camshaft Sensor Housing Gasket MD329503 1
Evo 8 Coil Pack Boots MD623073 2
Evo 8 Cylinder Head Rear Seal MD372348 1
Evo 8 Dipstick MD343884 1
Evo 8 Dipstick Tube MD342319 1
Evo 8 EGR Valve MR560582 1
Evo 8 Exhaust Cam MN143620 1
Evo 8 Exhaust Valve MD184078 8
Evo 8 Fuel Pressure Regulator MD320749 1
Evo 8 Fuel Rail MR561928 1
Evo 8 Head MN155744 1
Evo 8 Intake Cam MN143619 1
Evo 8 Intake Manifold MN137746 1
Evo 8 Intake Manifold Bolt MF241256 5
Evo 8 intake manifold bolt big MF241284 1
Evo 8 Intake Manifold Bracket MR560754 1
Evo 8 Intake Manifold Bracket Bolt MF140056 2
Evo 8 Intake Manifold Gasket MD310447 1
Evo 8 Intake Manifold nut MF430122 2
Evo 8 Intake Valve MD127840 8
Evo 8 Lash Adjuster MD377054 16
Evo 8 Lower Radiator Hose MN135593 1
Evo 8 Lower Timing Belt Cover MN143079 1
Evo 8 Oil Cap MN163112 1
Evo 8 Plug Cover MD345681 1
Evo 8 Rear Water Pipe MN143306 1
Evo 8 Reluctor MD375814 1
Evo 8 Reluctor Bolt MD368730 1
Evo 8 Rocker Arm MD375091 16
Evo 8 Spark Plug Gaskets MD186785 4
Evo 8 Spark Plug Wire Set MD343245 1
Evo 8 Spark Plugs MD374841 4
Evo 8 Thermostat Housing MN143307 1
Evo 8 Throttle Body MN128975 1
Evo 8 Throttle Body Gasket MD180361 1
Evo 8 Throttle Cable MN100169 1
Evo 8 Throttle Position sensor MD628074 1
Evo 8 Timing Belt MD326059 1
Evo 8 Timing Belt Front Cover MD334401 1
Evo 8 Timing Belt Rear Cover MD322517 1
Evo 8 Upper Timing Belt Cover MD373108 1
Evo 8 Valve Cover MN155455 1
Evo 8 Valve Cover Gasket MD340535 1
Evo 8 Valve Keepers MD016483 32
Evo 8 Valve Spring Retainers MN143698 16
Evo 8 Valve Spring Seats MD113424 16
Evo 8 Valve Springs MN158946 16
Evo 8 Valve Stem Seals MD306079 16
Old Dec 18, 2011 | 05:53 PM
mrg72433's Avatar
You might want to uprade pistons while you are there as the stock 64 pistons are weak
Old Dec 19, 2011 | 08:37 AM
Jabu's Avatar
I was just going to get it all put together and get it running before i started doing the build.
But how weak are they?
What kind of boost would be safe to run on the stock internals?
Old Dec 19, 2011 | 08:39 AM
thepoint4life23's Avatar
I think you need a spacer for the water pump to fit right with the evo head
Old Dec 19, 2011 | 11:44 AM
mrg72433's Avatar
most of the galant and eclipse guys have been seeing from 18-20 psi on a stock evo 8 or 9 turbo. The rods are the same as the evo's
Old Dec 20, 2011 | 12:14 AM
Jabu's Avatar
i have a spacer i just need to know what needs to be evo and what needs to be 2.4 when it comes to things i'm putting on the new motor from the old one.
and thanks mrg that's just what i wanted to hear haha
Old Dec 20, 2011 | 12:24 AM
mrg72433's Avatar
yeap no problem, do you have an evo?
Old Dec 20, 2011 | 05:37 AM
Jabu's Avatar
Yes i do bought it with a bad engine (cracked block) it has 50k miles and a few basic bolts on's and it's the sexiest car I've ever owned haha i just can't wait to drive it...
4 life
Thanks again guys!
Jabu
blonde
Jul 9, 2025 05:28 AM
evolve_VIII
444
Dec 16, 2020 08:11 PM
Raikiri
Nov 25, 2016 05:21 AM
Kojimagtrviii
May 24, 2014 06:15 PM
RussellM
MitsubishiParts.net - WA
120
Jul 25, 2013 11:37 AM
