Camshaft Suggestion for Evolution 7 ?
Old Dec 20, 2011 | 02:06 PM
Blood_shed's Avatar
Heya fellas
I've Evo 7 (2002) with specs below.What do you think abt HKS Camshaft Step 2 and the tune of cams? or do you have other brand suggestion that i can use.But the problem is I've already bought HKS Cam Pulley +HKS Belt + HKS Springs waiting to be installed along with the camshaft..My turbo project gonna start soon and the turbo will be Precision 6262.My aim is to push the engine around 700 hp limits which camshaft is gonna fit better to reach my goal.Thanks in advance
Camshaft i'm planning to install is
Exhaust Camshaft Step 2 Mitsubishi 4G63 CT9A
Brand: HKS
Product: Camshaft - Step 2 Exhaust Mitsubishi 4G63 CT9A
Part Num: 22002-AM012
SPECIFICATIONS:
Application: Exhaust Side
Duration: 278°
Lift (mm): 11.0
Valve Timing: 110°
HKS Intake Camshaft Step 2 Mitsubishi 4G63 CT9A
Brand: HKS
Product: Camshaft - Step 2 Intake Mitsubishi 4G63 CT9A non MIVEC
Part Num: 22002-AM011
SPECIFICATIONS:
Application: Intake Side
Duration: 274°
Lift (mm): 11.0
Valve Timing: 110°
Specs.
Stock ECU
HKS Racing Suction Reloaded Intake Kit
Greddy Complete Racing Exhaust
Exedy Stage 2 Racing Clutch
HKS Evc 6
HKS Bov
Old Dec 20, 2011 | 02:17 PM
JohnBradley's Avatar
How large a motor? 2.0L I might use something different than I would if it was a 2.4L In this case I would use the GSC S2 as it offers more lift, better centerline, and more aggressive ramp rate. Above that (again depending on engine size and head flow) I would go for either the S3 or a GSC custom S2 with extra lift.
Aaron
Old Dec 20, 2011 | 03:16 PM
Blood_shed's Avatar
Thanks for the reply
For later stages i'm planning to use 2.3l Stroker Kit along with Precision 6262 or Garrett GT42R
Can i use those 2 u ve advised with my
HKS Valve Springs Set Mitsubishi Lancer Evolution I~VII
Part Num: 22001-AM001
Found these 2 based on your advice
http://www.ebay.com/itm/GSC-S3-280-2...item2a1377d420
http://www.ebay.com/itm/GSC-Power-Di...item48421c27ae
Old Dec 22, 2011 | 05:51 AM
Blood_shed's Avatar
Does HKS Valve Springs Set Mitsubishi Lancer Evolution I~VII
compatible with these camshafts?.Cos i've already bought hks springs
I've sent an email to hks japan they told me that springs compatible with camshafts up to 12.0mm lift But they said that springs are specially designed to use with HKS Step 2 camshafts so they are not sure abt other manufacturer's cams.Any idea?.
Old Dec 22, 2011 | 10:05 AM
I havent used the HKS springs with S3s but that is the cam I would use on the larger motors for sure. We have a 3586/2.3/S3 car running around at 556 on pumpgas.
Old Dec 23, 2011 | 02:19 PM
browningderek's Avatar
I have decided my 2.3 with the 3586 with midrange cams like the s2's is just crazy! It makes soo much torque its hard to drive and traction is a joke. Im thinking i want to switch the the S3's to calm down the explosive hit and give me some more high rpm power. Big motors just need big cams.
Aaron, So S3's VS STM650's...... GO!
