Wtf! About to part this piece out!
Old Dec 24, 2011 | 01:38 PM
longdingydong's Avatar
ok let me explain whats happening. i installed my new 2.1 shortblock today. when i go to start it as soon as it starts something is stoping it. i can turn engine over by hand. its almost like the starter is stoping it from starting. i changed starter with a friends car and doing same thing. anybody ever had this problem. any ideas are welcomed and appreciated. merry christamas!!!!!!!!!!!!!!!!!!!!
Old Dec 24, 2011 | 01:40 PM
Pirana's Avatar
dead battery? do you have a mini-batt setup?
Old Dec 24, 2011 | 01:44 PM
battery relocated to the rear. but had jumper cables on the old battery terminal up front. had 2 sets of jumper cables one up front and one in back @ one time. idk im stumped
Old Dec 24, 2011 | 02:04 PM
Pirana's Avatar
Ok. I had a mini battery and the internal connection on the post was bad. Couldnt start the car or even jump it.
Old Dec 24, 2011 | 02:08 PM
it will start and turn over. but as soonn as it trys to start up. something is **** blocking
Old Dec 24, 2011 | 02:12 PM
evo8dreamcar's Avatar
Check your timing. I had the problem once and timing belt was off. Luckly didn't bend anything. Or try the jumper cable on the starter. Maybe the wire is oxidized.
Old Dec 24, 2011 | 02:40 PM
timing is dead on. checked about 10 times lol. might try jumping starter.
Old Dec 24, 2011 | 03:13 PM
cmspaz's Avatar
You can turn it over by hand endlessly and it's turning smoothly and freely?
How old is the fuel? High compression build? Could even be pre-ignition causing it to kick back, seen it before.
Old Dec 24, 2011 | 04:50 PM
Fresh fuel. 9:1 compression
Old Dec 24, 2011 | 05:22 PM
Always easier to rule things out. Check ground from motor also. Make sure it's grounded properly since motor was replaced. Easy things to miss
Old Dec 24, 2011 | 06:51 PM
ground @ trans connected. also ground on intake manny connected. dont think theres any other grounds
Old Dec 24, 2011 | 07:46 PM
cmspaz's Avatar
Just for ****s and giggles, have you tried bypassing the starter solenoid and seeing if it cranks continuously then?
Thought behind that, just to clarify, is that it could be a fault in the solenoid trigger circuit, be it the ignition switch, starter relay (I believe it's a normally open relay tied into the immobilizer circuit?), or the wiring itself, the latter being the least likely on a vehicle this new.
Again, ****s and giggles. As stated, the more random-*** crap we can rule out the better.
Old Dec 24, 2011 | 08:12 PM
shrtstuff89's Avatar
Or push start :-P
Old Dec 25, 2011 | 06:15 AM
tried somethings again. starter grinding bad on flywheel. stock flywheel. doesnt matter which starter i use. very sporadic when it grinds. sometimes doesnt grind @ all.
Old Dec 25, 2011 | 01:15 PM
dsaun772's Avatar
cmspaz is right... rule out the easy things before tearing things apart.
now when you say "something is stopping it" does the motor fire at all?
do you have a built head? and are you running stock injectors, and what tune are you running? you could be have a problem with pre-ignition of the air/fuel mixture
