Part Numbers for transfer case components ALOT of digging to find these.....
I don't know if this has been posted already. If so, please disregard.
After endless searching I have found part numbers for components needed to rebuild your own transfer case.
My Tcase is barely whining, its almost unnoticeable but being the perfectionist that I am I want to start gathering parts now so that I can rebuild it before it becomes worse.
Part numbers are for evo 7,8,9 w/ ACD and Without ACD
The Front diff carrier bearing for the ACD Tcase might be different for the rightside due to the clutch mechanism, I'm not sure though becuase my car doesn't have ACD and I hae never taken a non ACD Tcase apart.
So here it is:
Ring and pinion shaft kit 3.31:1 ratio = 3219A002 (rally art P/N)
Front diff carrier bearings w/ races = MR980099 (mitsu part number)
Front Pinion shaft bearing = MR980813 (mitsu part number)
Rear Pinion shaft bearing = MR553235 (mitsu part number)
SHIM KIT = MD745921 (mitsu part number)
BONUS:
Rear Diff ring and pinion = 3512A001 (rally art P/N)
If anyone has any more info on this PLEASE POST IT!!!!!!
I would be glad if someone found something wrong with these numbers because I don't want bad info either
We really need a good rebuild your own Transfer Case thread too, so I plan on doing that as well after I collect all the parts. IF I can collect all the parts.....
So here it is:
BONUS:
man that is awesom that you found these part numbers all on your own. did you happen to find a ring and pinion part number for the tcase for the people that need to rebuild theres from when they blew it apart launching it lol.... good find man.
Ralliart numbers dont work in CAPS/ASA.
These are the mitsu part numbers that work but have to come from Japan-
http://www.coordsport.com/transmissi...rnal-parts.htm
The only one to worry about- MD749696
Problem is the cheapest I have found them is 744 euro.
As an FYI, MD749696 is an Evo 4/5/6 transfer case ring and pinion; they are completely different from Evo 7/8/9 ring and pinions.
Here are a list of discontinued parts:
PINION SHAFT SHIM SET MD747961
CASE SPACER SHIM MD749806
FRT DIFF. CASE SEALING O-RING MD744201
FRT DIFF. OUTER BEARING SHIM MD746954
FRT DIFF. PINION GEAR HOUSING MD747952
FRT DIFF. PINION GEARSET MD749174
Here are a list of USA available parts:
FRT DIFF. OUTER ROLLER BEARING MD728354
FRT DIFF SPIDER GEAR SHIMS MN178197
TCASE INNER OIL SEAL MD745423
TCASE SMALL O-RING (TO TRANS) MD743612
TCASE LARGE INNER O-RING GASKET MD727944
TCASE LARGE OUTER O-RING GASKET MD752659
TCASE OUTER CASE SEAL MD747546
TCASE OUTER OIL SEAL MD755526
TCASE TAILSHAFT SEAL MR983368
FILL PLUG MD701850
FILL PLUG GASKET MF660036
DRAIN PLUG MB001265
DRAIN PLUG GASKET MN130495
BREATHER BULB MD733296
TCASE COVER MOUNTING BOLTS MF140231
TCASE TO TRANS MOUNTING BOLTS MF140289
TCASE TO TRANS MOUNTING BOLT(LONG) MS101368
REAR DIFF. RING & PINION GEARSET 3512A001
Here are a list of JDM ONLY parts:
PINION SHAFT NUT MD748003
PINION SHAFT OUTER BEARING MD746745
PINION SHAFT INNER BEARING MD746744
RING AND PINION GEARSET - Evo 4-6 Ratio MD749696
RING AND PINION GEARSET(RALLIART) 3219A002
FRT DIFF. IN & OUT THRUST WASHERS MD748089
FRT DIFF. PINION GEAR SHIM SET MD722982
FRT DIFF. ROLLER BEARING(NON-ACD) MR980099
FRT. DIFF. INNER ROLLER BEARING MD746743
FRT. DIFF. INNER BEARING SHIM MD743915
LSD FRT. DIFF. 3570A003
FRT DIFF. VISCOUS COUPLING UNIT MD747902
I can get the JDM parts, but they are anywhere from 45-100 business days to receive.
what is the rough cost of all the parts to rebuild ur tcase?? my buddy whos a mechanic will rebuild my spare 1 over a month or so on his down time, i basically just have to pay for all the parts.. .!
Well, you would have to get your own shims made. I used Maudlin - http://www.maudlinproducts.com/ for my 316SS shim stock and then had the dimensions measured and water-jetted out of stacks.
Its around $200 for the 4x bearings, $75-90 for gaskets and seals depending on the type of tcase you have.
If you need a ring and pinion, there are a couple places making upgraded ones in the USA that are anywhere from $1125-$1375 and stock ones are around $750.
Here http://autopartmaster.com/en/?action...R%20(C0-/CA-#) you can find almost every part number of all the car, since evo 4 to 9.
WTB[Northeast]: Transfer Case Cases/Housings (ACD pref)
SloEvo12
May 4, 2016 08:53 AM
desertsoldier22
Feb 17, 2016 08:51 AM
itsmeek
Sep 28, 2015 05:24 AM
AWD Motorsports
Feb 25, 2014 08:17 AM
Jacks Transmissions
Jacks Transmissions
Aug 24, 2013 07:00 PM
