need help! p0300 code and rough idle
Old Dec 27, 2011 | 12:29 PM
wekpcle123's Avatar
Is the car suppost to have the sorta miss like sound if it were just idled up a bit on a tune?
Old Dec 27, 2011 | 02:37 PM
wekpcle123's Avatar
Ok I reset the p0300 and drove the car some more today and after 20min of driving it threw a code at a relight and I was thinking it was the same code but when I checked it, its thrown a p0507 but no p0300.
Old Dec 27, 2011 | 02:49 PM
SilverShadow03's Avatar
P0507 means your idle speed is higher than expected... Double check the vac lines. Could be your IAC? Throttle position sensor?....you already checked and cleaned your TB...so this is all I got for ya....Good Luck!
Post back once you figured it out!!
Old Dec 27, 2011 | 06:32 PM
wekpcle123's Avatar
Rechecked all lines and everything looks normal. I tried adjusting the idle screw on top of the tb and rpms dropped to 850-950 but the slight missing is still there.
awdordie
Jun 15, 2017 10:00 AM
Jamesm331
Feb 29, 2012 08:32 AM
whitedemon
Jun 4, 2011 12:29 PM
CalebL
22
May 15, 2008 04:50 PM
