My Catch Can Setup
Im venting right now, no idle problems, but have a lot of blowby, and will not be rebuilding to late next year. So its a little annoying to see the gases coming out. I want to vent it back into the manifold. But having a catch can that inputs both the valve and crank case vents, I was wondering if I use a check valve at the manifold instead of the block (hence preventing pressurization of the can) I could still use both vent into the can.
The way I have mine keeps the dip stick in.I tested on dyno with a vacuum gauge on oil cap and before I would actually get positive pressure in the valve cover.after this I actually get vacuum in the valve cover at wot like -2 or so.I will try to make a video.
Get to hoses form the valvecover to the catch can ,
connect one hose from the turbo inlet pipe , to the catch can ,
connect one hose whit the pcv valve from the inlet mainfold to the catch can ,
and you are done ! running secure ,
if you are running long hoses , make shure to have the catch van mounter at a lower point then the valve cover and the inlet mainfold , ore ealse you will have the oil filld up in those hoses , and you will blow your dipstick ,
on this point och allways have sucktion in the can , and thts good from Hp view of point !
and you wont blow anny gasket on the crank , ore your oilstick .
hokiruu
95
Mar 21, 2012 03:13 PM
vtluu
Aug 10, 2006 08:56 AM
