Magnaflow fit in test pipe location
hi all,
need to quite things down.
Magnaflows 5" seems like it's the correct length, that has 3" opening
Anyone know if the diameter is going to be a problem or do I need to move it back?
I had two flanges welded onto a magnaflow round muffler similar to yours on my 06 MR. I used this instead of a testpipe or HFC. The five inch diameter will be fine and it will help quiet things down. A muffler shop did the installation and they did have to shorten the outlets to make it fit.
I thought it be cheaper with the Magnaflow.
Seems like with the flanges and muffler work I'm close to a HFC.
MAP has a Berk HFC that's claims to flow 87% of test pipe. That's close enough for me.
Soot and noise from test pipe is annoying.
Might give the HFC a shot
i run a 6" magnaflow can where the cat is supposed to go. Fits perfectly with the heat shield still on. Paid like 15-20 bucks to have a shop weld on 2 3" flanges on both sides. Quieted the car down a whole lot compared to a test pipe. IDK how the HFC will quiet down in comparison
i don't remember what i got, but after adding the flanges on each side it was a perfect fit lengthwise to the stock cat
If you ever plan to run more than 25psi on the stock turbo (or equivalent airflow on anything else) forget the HFC, you'll collapse it in 20k, over its 3 owners I don't think mine even had that many on it before I had to gut it.
I know the Bullet muffler used in the Buschur setup fits where the cat does, anything up to whatever that measures in at should be fine.
RallySport Direct
EvoX 'For Sale' External Engine / Power
18
Jul 21, 2015 09:10 AM
eez4life
Jul 3, 2012 03:42 PM
Revo15
Dec 30, 2011 11:29 PM
speedypollard
20
Jul 12, 2009 04:03 PM
