How Can I change from internal to external wastegate?
So my buddy just picked up a 06 evo ix has full tbe and is running on stock internal wastegate.
My question is what is the easiest way he can swap from internal to a external wastegate?
Iv read that a few ppl pull off the turbo and weld the wastegate shut I also heard others put a downpipe that just seals it shut- any of these ideas good?
I lean more towards pulling turbo off- but he doesn't want to do a lot of work to the car
Lmk guys
Thanks !!!!
Lmk guys
Thanks !!!!
Fairly Easy. I would just get an O2 dump. Weld the internal flapper open and cut the dump tube about an inch from the flange, weld on a Tial 38mm MVS and re attach the dump tube to the other end of the Tial 38mm MVS.
This is exactly what I did on my car and I made 750whp on a FP Black. Must be working
Mikey
Mikey
You can also just run an external downstream of your internal with the wastegate outlet seperate from exhaust.
http://www.maperformance.com/map-com...-cg40-o2h.html
autolove (Nov 9, 2023)
It's just my view but, the use of a setup such as the one Mikey and Chris are referring to may be slight overkill on a totally stock, and unported IX 16G turbo which is what the OP is asking about. This type of setup makes more sense on a full tilt, stock looking upgrade turbo such as the the Black, or the EF4, configured with relatively large wheels inside the stock housings.
For me you would be wasting your time and money installing the above described setups on the stock IX turbo. I am not taking anything away from the MAP unit. Theoretically at least, these setups have their place in more extreme applications. It just might be a little out of place on a totally stock 16G on a stock block motor. Just my O2 though.
So generally speaking - pointless to go to a external wastegate setup on a stock ix turbo?
He mostly wants to do it cuz he loved the sound of external dump.
I figured you could remove ix turbo weld the flapper shut then just run a turbo manifold that had attachment for a external wastegate
Will the turbo be hurt or performance if the internal flapper gets welded shut ?
Pointless, kind of. The stock turbo doesn't flow the ammount of airflow to really increase boost out the top regardless of what wastegate setup you have. This type of setup will help but in order to hold more boost out the top you will need a huge boost sprike (freeboost). You also need to know, just because your boost is higher out the top doesn't mean you will make more power. Over spinning a turbo creates a lot of heat and will hurt power.
The OP should just get a normal 02 dump and keep the internal flapper. Just preload the actuator to help it hold more boost out the top. You can also, if on meth or E85, induce boost creep to help top end power. Just watch the tq numbers if you are on the stock block.
My .02 cents
Mikey
My .02 cents
Mikey
