evo 8 transmission no quick shift
Old Jan 18, 2012 | 12:30 PM
triple L's Avatar
so i just installed my BR3582R and fic1050cc and got it street tuned on pump... my rev limit was set @ 8200rpm with 272 kelfords and supertech springs/retainer.... but my problem is my transmission keeps locking out at high rpm so i can't shift fast enough... my transmission has been rebuild by FFTECH and i have gone through so many gear oil selections but it is still the same... any advise or recommendations how i can fix this?
Old Jan 18, 2012 | 12:34 PM
escodotcarter's Avatar
What clutch do you have?
grillpt's Avatar
What clutch is in the car?
SilverShadow03's Avatar
Have you contacted FFTECH for their input? Describe your issues and lack of finding an acceptable solution on your own and see what they say or suggest.
Also what kind of clutch are you on and how many miles is on it?
Old Jan 19, 2012 | 12:58 AM
triple L's Avatar
i bought a stage 4 comp clutch with their flywheel and had FFTECH put it in when they did the rebuild but i had this issue even before i took my car to them... i was hoping after the rebuild it would fix the problem... it just seems or feels the teeth/gears/synchros are not lining up fast enough... i haven't check my mounts yet but i don't think it may cause this problem... clueless now...
Old Jan 19, 2012 | 01:06 AM
triple L's Avatar
the clutch/tranny rebuild has about 7500 miles on it... but ever since i've never launch the car... just a few freeway pulls from 50-140
Old Jan 19, 2012 | 12:22 PM
triple L's Avatar
bump tt
Old Jan 19, 2012 | 12:40 PM
blowngasket's Avatar
hows it shift when you double clutch? what RPM does it lock out at? hows it shift with the car off?
Old Jan 19, 2012 | 12:48 PM
triple L's Avatar
when engine off goes in smoothly... only locks out after 7k rpms or around-ish and no... double clutching doesn't work as well ...ive tried few other things but im afraid i might bust the synchros again.... i might as well get it rebuild at sheptrans or get a new one
Old Jan 19, 2012 | 12:54 PM
triple L's Avatar
it usually does it from 1st goin into 2nd and 3rd goin into 4th and 4th goin into 5th... i dont usually take it that high on 4th but trying it and yes it does lock out after 7k rpm i have to wait probly half a sec to get into the next gear and i dislike it...it gives me a huge lag
Old Jan 21, 2012 | 01:50 PM
triple L's Avatar
ttt
Old Jan 24, 2012 | 01:47 AM
triple L's Avatar
any other inputs?
Old Jan 26, 2012 | 09:56 AM
twicks69's Avatar
Clutch adjustment issue as it is not fully disengaging. Bleed and adjust your clutch hydraulic system and adjust your clutch pedal adjustment rod toward the firewall until you get complete disengagement of the clutch when you depress the pedal.
Old Jan 27, 2012 | 01:06 AM
triple L's Avatar
im gonna try dat thnks for all inputs
Old Jan 27, 2012 | 08:22 PM
millsyy17's Avatar
Veteran: Army
sounds like your getting what we call "lock-out" at high rpms...its been known with clutchs like ACT ect. Like twicks69 said, try adjusting the clutch, that helps alot
loosen the 12mm nut on the clutch master cylinder rod by the clutch pedal and turn it counter-clock wise so there is a bit more travel in the pedal. Give that a shot and let us know
