adjust vacuum with balance shaft delete?
Old Jan 19, 2012 | 12:03 AM
fireroasted's Avatar
Some time ago I was considering the balance shaft delete, since I was pulling my engine. I have it out, but I am not building the bottom end. I am doing cams, intake, injectors, etc. I read that the 272/272 kelfords I am putting in will drop my head pressure in the engine. First of all, is that correct?
Second, does it make sense to try to address that with an apposing mod? I also remember reading that doing the balance shaft delete increases pressure, so I was thinking if it would be logical or beneficial to do the balance shaft delete, even though I don't have a balanced crank, to free up that little bit of power, and help even out the pressure difference from the cams.
The feedback I received from most of you a few months ago was not to do the BSD unless you are running a built and balanced bottom end. One of the Cons was the oil pressure.
Thanks
Old Jan 20, 2012 | 12:02 AM
Bump,
Come on guys, someone educate me on this pressure/vacuum thing I don't understand. If the balance shaft delete increases pressure and the overlapping cams reduce pressure do they go together well? Just trying to figure out if I should do the BSD while I have the motor out. stock block and head with 272 cams.
Thanks for any explanation on oil pressure as a system in the engine.
Old Jan 20, 2012 | 07:37 AM
n2oiroc's Avatar
removing balance shafts will increase oil pressure, but they wont change vacuum at all. cams will lower vacuum but they wont change oil pressure.
honda-guy
40
Aug 2, 2015 07:37 AM
dsmerjosh
10
Apr 11, 2015 03:27 AM
binky
Automotosports - Illinois
11
Mar 6, 2010 11:08 AM
prchico19
Sep 15, 2009 06:35 PM
phil_
Lancer Engine Tech
Jan 30, 2006 11:14 AM
