(Video) Boost Activated Cutout - My new favorite mod!
Old Jan 23, 2012 | 06:00 AM
domestickillaAR's Avatar
ive wondered how well these work and what kinda gains you can expect from one.. ill be on a 2.1 Aluminum rod motor with a 3586hta so im very curious to see more feed back on your setup.. can you disconnect the vacume and do a back to back test for throttle responce or any increase in spool... honestly if it wernt for the cost id get it just for the sound. great job..
Old Jan 23, 2012 | 07:24 PM
10isace's Avatar
Just ordered mine.
Old Jan 24, 2012 | 01:09 AM
evilempire76's Avatar
Originally Posted by 10isace
Just ordered mine.
Awesome man. You won't regret it one bit!
Old Jan 24, 2012 | 09:44 AM
okevolutionVIII's Avatar
Originally Posted by BluEVOIX
I'm also planning to do that as well. I'm running the Works catback mated to OEM muffler and plan to install a boost actuated cutout right behind the muffler.
Yes you are correct that it is expensive and in my opinion more than it should be.
Using a Works setup with the modded OEM muffler was my original plans but it was a lot of money to go with that setup at the time but cutting weight and noise was what I was looking for and the Varex setup I'm having made is perfect for that.
I've read that boost actuated valves didn't help power delivery but that might have came from very picky people that only run 10psi on small turbos. I looked for one to purchase last year and never found one in stock. It looks very promising though.
Old Jan 24, 2012 | 09:56 AM
Sidnakit's Avatar
sick man.. were did you get that dash pod? i wanna mount gauges there like that but cant find that pod..
Old Mar 21, 2013 | 02:56 PM
abazaba410's Avatar
Im bringing this back from the dead...
Any wear and tear results? Did everyone have to install it backwards?
Old Mar 21, 2013 | 02:59 PM
10isace's Avatar
Mine is backwards. I thought the exhaust would heat up the WG actuator and ruin it, but it's been good. I DD with it for a year. It leaks a little since new (rumble), but it's a lot louder under boost
Old Mar 21, 2013 | 08:08 PM
abazaba410's Avatar
I think that is the route Im gonna go
Old Mar 21, 2013 | 08:34 PM
mullen's Avatar
This is a pretty cool idea, I don't have a use for it at the moment but I will definitely use this on a future project
rocknsnoboarder
Aug 9, 2016 05:23 AM
Terror Rising
Apr 20, 2013 06:02 PM
Jameson_IXMR
Jan 23, 2013 12:27 PM
anthonyrb98
Nov 8, 2011 07:03 PM
Jameson_IXMR
17
Jun 14, 2010 06:50 PM
