2.4 long rods??
Old Jan 29, 2012 | 03:25 AM
evoyrrah's Avatar
2.4 long rods??
Is rue you can get 159mm long rods for the 64? If so, which pistons suit them? Would it be ideal having such a small piston? I'd like to where I could get my hands on this combo for my next build
Old Jan 29, 2012 | 06:17 AM
n2oiroc's Avatar
156mm is pretty much the longest you want to go.
Old Jan 29, 2012 | 08:50 AM
jonzie04's Avatar
you can get 159mm rods. can also get 162mm rods... but they would require an expensive crank and pistons.
Old Jan 29, 2012 | 09:59 AM
NewEvolutionIX's Avatar
Im building a 2.4LR with Manley 156mm rods and Weisco 10.5:1 87mm pistons
Old Jan 30, 2012 | 11:37 AM
MikeB@FFTEC's Avatar
We typically use off the shelf 156mm rods.
Old Jan 30, 2012 | 11:41 AM
JohnBradley's Avatar
Are you trying to build a LR2.4 or just use the 4G64 block and build a different displacement?
Aaron
Old Jan 30, 2012 | 08:07 PM
burnzy's Avatar
at 2.4 156 is the most you really want to go, thats with the pin already moved up 6mm, same as a stroker style 2.3 piston, taking another 3mm off the crown to wristpin area i'd be wary about, if in fact even possible at normal compression ratios.
Old Jan 30, 2012 | 08:18 PM
Steel rod only and it gets close with a 10:1.
I used that compression height in my 2.2 (in this case 25.7mm) with R&R and I had to machine the piston a little to make it fit. The JE I used at that time still had 8mm of crown thickness in the 10:1 and according to manufacturers I have talked to since, 6.5mm is the bare minimum. I would think it would mean you'd want a 10.5:1 or 11:1 piston to make it work right and have some peace of mind. In retrospect we'd never build a motor like that again, the 8mm of thickness above the pin on the rod at that compression height didnt work well. A steel rod would have added back what I needed most likely though I dont know the difference in measurement off the top of my head. I will find out though tomorrow.
aaron
Old Jan 30, 2012 | 08:22 PM
burnzy's Avatar
159 with 10.5 would be ideal on e85, our e85 in australia isn't very stable and as such people are a bit weary of having to be stuck with e85 to get most performance from a high comp engine. at 9:1 it would be under the 6.5 limit wouldnt' it?
Old Jan 30, 2012 | 08:25 PM
Agreed.
Yeah the dish would interfere I think. A 9:1 156mm is good to go however
Old Jan 31, 2012 | 01:06 PM
craigybaby37's Avatar
You can get 162mm rods if you want to de-stroke the 4g64 bloks and have a super long rod 2.1 revving to 9k plus
Here is a thread from MLR taking about the 2.1 long rod using 162mm rods, 87mm pistons and a 88mm stroke crank on the 4g64 block.
http://www.lancerregister.com/showth...super+long+rod
Old Mar 4, 2012 | 11:58 AM
OsideEVO's Avatar
Im look for piston for my 2.4 LR. 156rods. Heard of few people using stroker pistion. Is that the correct way or is there a company that makes LR pistons .
Old Aug 10, 2012 | 09:11 AM
bader's Avatar
What pistons would you use for a 2.4l with 100mm crank and 156mm rod.
Old Aug 10, 2012 | 10:16 AM
94AWDcoupe's Avatar
does anyone have a shelf stock 153mm or 159mm rod?
Old Aug 10, 2012 | 10:23 AM
izabran's Avatar
i need the answer as well
