wich sparkplugs for E85 600 hp?
Old Feb 5, 2012 | 03:53 AM
Nickolaus's Avatar
Isnt it the same for the 8 as the 9 ? i made a order of BPR8ES i hope it will work good?
Originally Posted by bbyevo8u
why is everyone recommending him evo 8 plugs when he has a evo 9....lol
Old Feb 5, 2012 | 04:07 AM
cody92talon's Avatar
well you better cancel that order man because the 8 and the 9 are not the same the 9 has to use a iridium plug
Old Feb 5, 2012 | 05:18 AM
Nickolaus's Avatar
Ok, why does it have to use iridiums? I really dont wont to use them on e85
Old Feb 5, 2012 | 07:26 AM
Steven's Avatar
You don't have to use an iridium plug, but that's all that's available right now for an IX. The BPR8ES is too short. I'll try to find the specs.
Old Feb 5, 2012 | 07:33 AM
Steven's Avatar
BPR8ES
Traditional Spark Plug, 14mm Thread Size, 19mm (3/4") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Resistor, Removable Terminal Nut, JIS Height, Projected Tip, .031" (0.8mm) Gap, Heat Range 8
Exact Match:
Spark Plugs NGK Traditional spark plug 3923 BPR8ES $2.89
Old Feb 5, 2012 | 07:34 AM
Steven's Avatar
Extreme Long Life Laser Iridium Plug, 14mm Thread Size, 26.5mm (1.04") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Projected Tip, Solid Terminal Nut, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Tapered Cut Ground Electrode, .024" (0.61") Gap, Heat Range 7
ILFR7H
Spark Plugs NGK Laser Iridium Long Life 5245 ILFR7H $12.06
List applications for part number ILFR7H
Old Feb 5, 2012 | 07:40 AM
Steven's Avatar
You can see that the Evo 8 plug (BPR8es) has a 19mm reach and a 13/16" hex head size, while the Evo 9 plug (ILFR7H) has a 26.5mm reach and a 5/8" hex head size. I've used the ILFR7H and was very happy with them, and about a year ago started running the Denso IKH24 (1 step colder than stock) The Denso IKH22 is a direct cross with the stock NGK ILFR7H.
TeRoy EvoIX
Aug 20, 2013 07:49 AM
Rocky_RA
Apr 22, 2012 01:35 PM
DBTurMOMtchzME
Jun 14, 2011 08:40 AM
DutchEVOVIII
E85 / Ethanol
Mar 3, 2011 09:41 AM
Robevo RS
14
Mar 26, 2008 06:44 PM
