compression ratio for 600-700 hp
Old Mar 20, 2008 | 07:08 AM
Robevo RS's Avatar
One of my friend want to build a Time attack car in EU. so he asked me what is the good Compression ration for a 2 liter 4g63 on that level and wich turbo would be a good choice?
Any technincal info would help.
He really looking for the compresiion ratio for a 2 liter engine and maybe the valve size , the turbo size would help too.
Thanks for your times guys.
Old Mar 20, 2008 | 12:53 PM
JohnBradley's Avatar
What fuel is it going to run on? That determines alot of the answer to your question. The next is this 600whp or 600 at the flywheel? A GT35 or similar size will meet both of those requirements and then some.
Old Mar 20, 2008 | 01:07 PM
tripperfx3's Avatar
The higher the compression ratio the more power you can make with less boost (Mazdaspeed 6 and 3 for example had a 10:1, roughly, compression ratio, but is only able to do so due to its DISI ignition system). So rule of thumb is to drop the compression ratio. Not sure with the 4G63, but some of the high HP SR20DET's are running around a 7.5 to 8.0:1 Compression ratio.
Old Mar 20, 2008 | 02:22 PM
Robevo RS's Avatar
he will run on race gas, sorry i forgot.Yes the hp is what he was telling me at a crank. So i guess that is why he said between 600-700 hp. /funny even we have dyno's there too they still talking about crank hp... /
thank you guys , i greatly appropiate your help, here.
Old Mar 20, 2008 | 02:28 PM
wroblewskievo's Avatar
this would be the way to go for road racing but it is a 2.3.
http://www.amsperformance.com/store/...oducts_id=1639
Old Mar 20, 2008 | 02:29 PM
Robevo RS's Avatar
the rules are only 2.0 l , period.
Old Mar 20, 2008 | 02:37 PM
that's what i thought. i wonder if they can do a rr treatment on a 2.0?
Old Mar 20, 2008 | 03:33 PM
Robevo RS's Avatar
they racing along time ago in the rally.
But they got a bug from somebody... / / for road race. So they will start doing it this year. They just need a set up for it. and since its different ball game , need some help for starters. It is makes easyer.
I just talk to them so will be a 288's brian cover cams ,35 R and race gas for sure.
But we still need to find out the close to optimal Compression ratio for that set up. And maybe some suggestion for the valve's.
Thanks.
Old Mar 21, 2008 | 10:40 AM
slugsgomoo's Avatar
running on race gas, I'd run higher compression, since you get better off boost response, somewhat less lag, etc. There are other benefits, but I'm over simplifying.
I would consider 9:1 or even 10:1 depending on the fuel you're going to run.
Hell, stock compression is what, 8.8:1, and people make plenty of power on that.
Old Mar 21, 2008 | 10:45 AM
westcoastkiller's Avatar
Id stick with 9:1
Old Mar 21, 2008 | 02:29 PM
Robevo RS's Avatar
thanks guys
Old Mar 21, 2008 | 05:53 PM
andy hiralall's Avatar
I say go with 10:1
Old Mar 24, 2008 | 08:33 PM
bamf9se's Avatar
I support 10:1, can make your power running less boost.
Old Mar 24, 2008 | 11:19 PM
GT42R FTMFW's Avatar
9.5:1 + GT35R, less boost, but higher revs, however:the higher rpm, the harder it is on the engine, rings will need to be replaced more often.
Old Mar 26, 2008 | 06:44 PM
CliveW's Avatar
I run 9.4:1 on a 2.2 stroker with a GT35R, producing 621Bhp on 97Oct with quite aggressive timing, but I also spent a lot of time on the combustion chambers, reprofiling the chamber and modifying the squish to reduce chance of detonation. Comp ratio isn't always the whole story!
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 11, 2016 08:15 PM
Ronnie Size
Nov 22, 2012 06:17 PM
Johnboy1065
18
Jun 21, 2009 09:37 PM
ambystom01
Jan 20, 2008 01:35 PM
ill-luzion
Oct 28, 2007 06:29 PM
