View Poll Results: How many have lost coils/Cam sensors with the Spooinup COP kits?
Have?
12.50%
Have not?
87.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Lost spark.....two inside cylinders....spooning up COP
Old Feb 6, 2012 | 03:44 PM
utripin's Avatar
Title says it all..going to try stock coils. Also have a second ecu.
Found my problem.....wasn't the coils after all!
SORRY Matt!!!!!
Last edited by utripin; Dec 11, 2012 at 11:53 PM. Reason: mistake in the first post
Old Feb 6, 2012 | 03:54 PM
wjamyers's Avatar
literally an hour after I ordered mine! you gotta love the intarwebs...
meh. I aint worried.
Old Feb 6, 2012 | 03:57 PM
EvolutionKid's Avatar
spooning
did u buy a new or used kit?
Old Feb 6, 2012 | 04:11 PM
06RedRalli's Avatar
Have you checked fuse #1 under the dash?
Old Feb 6, 2012 | 04:38 PM
utripin's Avatar
New coils, fuse was the first thing I checked. about to check old packs.
Old Feb 6, 2012 | 05:22 PM
utripin's Avatar
Same two outside cylinders are firing with stock coil packs..... Something else is wrong. much brighter sparks? is the dwell different betweenthe two?
Old Feb 6, 2012 | 05:28 PM
Spec-Ops1's Avatar
The dwell is the same unless you changed it in the ECU... I had my fare share of issues with the spoolinup kit, not that it is a bad design, but it just didn't jive with my car...there are plenty of people out there running around with the kit with zero issues... I blew 3 different sets of used coils, the last time they blew it also took out the cam sensor. Since that day, I replaced the cam sensor, and went back to the oem coils, and have had zero issues...
BTW, every time a coil bit the dust it was on cylinder 2... the last time it took out cylinder 2 & 3...
Old Feb 6, 2012 | 05:52 PM
meckert's Avatar
Curious-- did your COP just blow out the coils where they went out completely all at once? I ask as I have a very intermittent problem, like a cylinder kicking out and a spark misfire- a slight miss at light throttle where you can feel it in the gas pedal. Only does it on a cold start when it happens. But can go months with no issues, then it kicks in and goes for a couple of min then gone again. In a std car it would be just like a loose plug wire. Is this what you guys are experiencing?
Old Feb 6, 2012 | 06:03 PM
Spec-Ops1's Avatar
That is what happened to my car before they would bite the dust... it generally happened to me while I was on the interstate (missfire type issue)
Old Feb 7, 2012 | 05:39 AM
utripin's Avatar
This is exactly what mine did! same to the T! I got a check engine light too..P0340 cam postion sensor circuit while at idle in my garage, right before it stopped! Oh Matt.....
Old Feb 7, 2012 | 05:55 AM
utripin's Avatar
I'm going to check coils with a muti meter later today. I hope to get a refund for the kit. I'm feeling that I need a new cam sensor and who knows how many stock coils??? How can this happen on so few Evo's???? Puzzling?? Was running fine, I thought, because I'm running SD I thought I was having the jitters. Damn I'm so confused, and broke!! How do I get a hold of Matt? Does he have a phone #, or is it just by email? HELP.
Old Feb 7, 2012 | 06:03 AM
kmcconn9's Avatar
Had the same issue..good luck.
Old Feb 7, 2012 | 06:16 AM
Ev0ikon's Avatar
Do you have a shield for your cam sensor?
I am lucky with my used SpoolinUp kit. I even run it with the HKS twin-fire amp. 40+ PSI with TONS of water+meth and it doesn't even snuff out the sparks
Old Feb 7, 2012 | 06:38 AM
utripin's Avatar
Yup I have a shield.....why me ?
Old Feb 7, 2012 | 06:57 AM
EvocentriK's Avatar
I have heard of this happening with a TM Works kit too. Guys car blew the same coil 2 or 3 times then switched to a spoolinup kit and its been fine since.
Could this have anything to do with the coil charge time settings in the rom? Perhaps need modification for the denso coils? Doesn't really explain why certain cylinders would be more commonly affected though.
