slight metal shavings in oil
Old Feb 13, 2012 | 09:17 AM
Q15H's Avatar
Just for kicks though, you did replace EVERYTHING right? Pan, pump, pick-up, cooler, filter housing, lifters, hot tanked everything, old AND new?
Veryh good point!
Just because it's new, doesn't mean it's *good* or that it's clean! Clean, inspect before using ANYTHING.
I personally wouldn't hot-tank new stuff - I prefer brake cleaner and isopropol alcohol. Same way I rinse stuff that's been hot-tanked. Bot-tanking (and other heavy solvent cleaning methods) just loosen up the crud - stuff still needs to be brushed, cleaned & rinsed (and sometimes painted). Especially internal oil passages.
Old Feb 13, 2012 | 03:18 PM
unijabnx2000's Avatar
have you sent your oil off for testing at a lab?
Old Feb 14, 2012 | 08:50 AM
bubba17's Avatar
not yet im hooking up the rest of everything tonight firing it up and driving it around for 50 miles and pull the oil and then send it out
Big_FN_Target
Sep 7, 2014 09:40 PM
Levar
Oct 11, 2012 11:59 AM
Evo3573
50
Sep 17, 2011 05:15 AM
czilla
20
Mar 11, 2011 10:47 AM
tripperfx3
Sep 30, 2008 02:33 PM
