4inch Downpipe & 4inch Aluminum Exhaust
Old Feb 14, 2012 | 04:57 AM
giangi's Avatar
Originally Posted by way2qik
If you aren't running full length exhaust, I'm not sure it would make any difference on your setup. But when it comes to turbos, my personal experience tells me that turbos work best with no restriction at all.
If you ran full length 4inch to the bumper, you may see the same results as your short 3inch pipe you are currently using. Spool up might be a little slower with the longer piping, though...
Actually i'm running a 4" od short pipe, a complete exhaust system to the bumper would be great as it's less loud, but the route under the oil pan and the weight are two great cons about this solution, i did a big work to put my evo 6 tme under 2250 lbs, i think i will keep my ultra short exhaust....
Old Feb 14, 2012 | 06:46 AM
way2qik's Avatar
Sounds like a monster.
Old Feb 14, 2012 | 03:26 PM
way2qik's Avatar
Made a little more progress... We're going to re-do the tip to lengthen it a bit more. But its getting closer and coming together nicely. Fits very well.
Attached Thumbnails 4inch Downpipe & 4inch Aluminum Exhaust-img_0213.jpg   4inch Downpipe & 4inch Aluminum Exhaust-img_0214.jpg   4inch Downpipe & 4inch Aluminum Exhaust-img_0215.jpg
Old Feb 14, 2012 | 03:57 PM
EvoDan2004's Avatar
When I'm done I'll try to weigh it all. I currently have a old (like 6yrs old) Perrin 3inch, street version exhaust. Its very heavy. The muffler is extra large, much larger in fact than the typical conical muffler on most 3inch systems. The muffler itself weighs, with the tip and lead in piping, at least 40lbs.
My car made 780whp on a Mustang dyno last year through 3inch exhaust. That equates to about 900whp on a Dynojet if you use the average 13% higher reading that the Dynojet will give. We were beginning to see the results of back pressure as the boost got turned up to 40+psi. This exhaust will definitely allow us to make more power, and will allow us to do it easier.
So, you can agree with Dan, but I'll ask you both this - How much horsepower have you made through a full length 3inch exhaust? What is your personal experience with this? Or, are you just a pro from reading what others tell you here on Evom?
You might want to recalibrate your hand sales. Your not gonna drop 75lbs. As for the 4 inch Bs. When comparing it to the ****ty perrin exhsust you are replacing it with thst is already restrictive then yes your exhaust will make gains. So will a properly built 3 inch unit. The turbo you pictured I hope is jot what your planing to use. Looks like a 3.0 vband housing. So again I do not see you picking up any worth while gains over s lighter 3inch exhaust. I dont make hulk hogen power like you do but I believe I made enough to see any gains from my old 3.0 to 3.5 inch exhsust. I saw nothing. And if your under 900 i dont think you will either. Well from the perrin to the new one you will. But from a properly built 3.0 you wont and again if you do its minimal
Old Feb 14, 2012 | 04:14 PM
way2qik's Avatar
You keep contradicting yourself... First it was only if you make 900.... Then I demonstrated that on a Dynojet this car would make that and then some.
Furthermore, I already told you what I made through 3inch. If you didn't make what I already made why did you bother putting 3.5inch exhaust on your car? No wonder you didn't pick up any power, genius. If you went a best of 141mph, that's about 500whp on a Mustang dyno. We've got a guy in our area who made right about that amount on a Mustang dyno and went just as fast as you have.
So, I've already made about 200hp more through 3 inch than you have, and I know for a fact I've found the limits of that diameter tubing. I could have just as easily gone 3.5, but you know why I went 4inch? Because I can. That's why. Oh, and to **** off know-it-alls like you
ps. consider for a moment the power this car made through that sh**** perrin exhaust, and then compare it to what you've made through 3.5inch.... LOL!
Old Feb 14, 2012 | 04:27 PM
EvoDan2004's Avatar
Your math is wrong again.But do what you have to do and let's see this car do sub 8s to merit it needing this exhaust. A few shops run in the 8s with 3 inch. Good luck with your project. At first I had interest and when i asked for a reason to your madness over what was already proven to work your comment showed your character. Now I have no interest.
Old Feb 14, 2012 | 05:06 PM
way2qik's Avatar
Thank you. Now please move on along there, little fella
Old Feb 14, 2012 | 05:25 PM
hks-gst's Avatar
Great work on the exhaust setup.
Old Feb 14, 2012 | 07:37 PM
domestickillaAR's Avatar
Any reason you went with a Vibrant muffler instead of like a Burns stainless bullit ? This is the muffler ill be usen on my project.
http://www.burnsstainless.com/sm-400-550-12.aspx
Old Feb 14, 2012 | 07:45 PM
B.J.@ToxicFab's Avatar
Exhaust is aluminum, not stainless....
Old Feb 14, 2012 | 08:28 PM
evilevo2006's Avatar
I am sure you do not want to here this either but i also agree with evodan. your only going to see gains ''miss leading gains'' over that Perrin exhaust. if you were to put a real 3 inch exhaust on the car and then do a test your gain will be minimal if at all. Not to mention your going to have less ground clearance with the 4 inch exhaust. but you can believe in whatever it is your fooling your self with. lets see this car run sub 8s high 7s to hold up to this ''supra'' style exhaust.
Old Feb 14, 2012 | 09:08 PM
detroit pistins's Avatar
I don’t think many will doubt it, but you gotta keep in mind, depending on the length of the 3’’ exhaust, the pressure drop per unit length due to frictional losses is a lot greater for those running the full length exhaust vs short exhaust going out the side of the front bumper. So, using a 4’’ all the way thru, will reduce these friction loses, but at the price of decreasing flow velocity (spool). ofcourse this is more noticable for those making higher power, as the loses are more noticable.
Also on the hotside size note, our stock turbo O2's are around 2.5'' if I am not mistaken, and using a 3'' still results in higher gains. so correlating the size of the the outlet to that of the tubbing is irrelevant imo. people with stock turbos should be using 2.5'' exhaust if thats the case.
Either way, let’s wait and see what his setup results in, I think if it doesn’t make any power, it will atleast educate us all!
Old Feb 14, 2012 | 09:27 PM
EvoDan2004's Avatar
im only replying to your post. i agree a side exit VS a full exhaust makes a difference. in case i was miss leading i was talking about full exhausts only. STM runs a 3 inch exhaust on a car that runs 8.7s @ 167. BR has more 8 and sub 9 second cars all on 3 inch exhausts. the OP'er is comparing a bull **** perrin exhaust to a real ''in his case'' 4 inch exhaust. yes there will be a gain but it is a miss leading one IMO. if he was to put a real 3 inch exhaust on the car i do not see any gain. and being he is also looking for weight reduction a 3 inch would be lighter.
as for his turbine housing and the 3 inch Vband. i am with you 100% on what you said but i only brought that into the equation because i said i do not see that turbo he posted pics of ever needing a 4 inch exhaust on it. i asked nicely if he was keeping that turbo or going to something else but he seems to have a problem with talking. so let him figure it out.
Old Feb 14, 2012 | 11:16 PM
way2qik's Avatar
What happened to "now I have no interest?" You just can't help yourself, can you?
Listen, you just need to face the fact that I HAVE A BIGGER PIPE THAN YOU!
Old Feb 14, 2012 | 11:39 PM
way2qik's Avatar
Ground clearance will not be an issue. The bottom of the pipe will be about even with the bottom of the side skirts once we are finished with it. Besides, if ground clearance is the issue, then I shouldn't have put the CF front lip on the car, but I've never had a problem with it. The lip is much lower than this exhaust will ever hang.
This car will NEVER run sub 8s and high 7s. How many Supras have done that even making over 1000hp? Most people could never drive a manual-transmissioned car to those kind of times (and I include myself in that group). This car would have to have an automatic in it, and be lightened up ALOT.
Attached Thumbnails 4inch Downpipe & 4inch Aluminum Exhaust-311857_10150852833385440_796640439_21180830_438040675_n.jpg
