What is considered too light of flywheel for DD?
Old Feb 16, 2012 | 07:00 AM
Firebat's Avatar
Hi all. So I finally got my Comp clutch and am waiting on my flywheel. I ordered the comp clutch flywheel 2-645-STU. Heard it weight just over 11 lbs.
What is considered to light of a flywheel for a daily driver. Car makes 320 whp.
I was told the flywheel will be fine and no prob with check engine lights. I was going to get a new OEM one but couldnt fine one less than 400.00.
I was also told by a known performance shop that they dont recommend resurfacing OEM flywheels cause they tend to warp.
thanks in advance.
Old Feb 16, 2012 | 02:20 PM
sourcelx's Avatar
I've never heard of a flywheel being to light. The lighter the better( less weight for your crank to have to throw around).
Old Feb 16, 2012 | 02:30 PM
SilverShadow03's Avatar
I don't have a lightened flywheel installed (resurfaced OEM - no problem/warpage there!) but others on here have said their lightened flywheel is not as smooth compared to the OEM unit.
Maybe others can chime in.
Old Feb 16, 2012 | 02:35 PM
thisxguy's Avatar
lighter flywheels allow for quicker revving, but your car will have a little more trouble getting off the line. I have a lightened flywheel that weighs in at 10.7 lbs with a ACT XTSS. I didn't notice much of a difference but the car is smooth. the car isnt as smooth from a stop as the stock clutch. But overall, I like it.
I have a friend who resurfaced a stock flywheel and it was not nice to break in. and I have another friend who resurfaced stock flywheel and he had no problems.
So, overall, I would say that if you can afford a flywheel, then go for it. But I honestly haven't noticed much of a difference.
Good luck
Old Feb 16, 2012 | 03:04 PM
FJF's Avatar
FJF
Stock (new or resurfaced) and ACT Streetlite are about the same weight (~13.5lbs) and are usually recommend for DD applications. Personally, I wouldn't run a lighter flywheel on the street. There's virtually no real benefit and the drivability suffers. Good luck.
Old Feb 16, 2012 | 08:44 PM
Firebat's Avatar
Thanks for the input guys.
Old Feb 17, 2012 | 09:19 AM
dastallion951's Avatar
i have an act prolite flywheel and hdss on mine, other then stop n go traffic itll wanna buck sometimes, its all in the clutch pedal modulation to help with that. But I like mine it revs a lot faster compared to stock flywheel. Any time you reduce sprung weight ie reduce the amount of weight to turn a part, it makes a significant difference.
newevoxguy
Mar 22, 2017 05:19 AM
austin_davee
Dec 29, 2016 04:47 AM
hutch959
Dec 5, 2016 05:10 PM
kboy808
Lancer Tranny/Drivetrain Tech
Apr 27, 2015 05:44 AM
BaLListic_EVO
Dec 1, 2005 03:05 AM
