Required mods for 400whp IX MR on e85?
Old Feb 18, 2012 | 07:13 AM
cbseven's Avatar
Thanks up front for the insight.
I have an 06 IX MR with ~35k miles. Looking at what mods are required to bring it up to 400whp. What do you guys see these being - and if you have a recommendation on a specific brand, would gladly welcome your input.
Old Feb 18, 2012 | 07:45 AM
hiner005's Avatar
Injectors, fuel pump and tune for E85. Done
Old Feb 18, 2012 | 10:08 AM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
What are you going to use the car for? Drag, autox, track?
Old Feb 18, 2012 | 10:23 AM
dangle's Avatar
Turboback exhaust, filter, upgraded diverter valve, tb seals, injectors, fuel pump, and something to control boost. I like a 3 port bcs and omni 4 bar for ecu controlled boost. You will need a clutch if you don't have one.
Parts that would squeeze out some more power:
Intercooler and piping
02 Housing
Ported exhaust manifold
Ported Hotside
I have all of that and made 427awhp/391awtq
Old Feb 18, 2012 | 10:52 AM
Ian0611's Avatar
02 Housing
Ported Hotside
This ^^ is a pretty good list.
As far as brands go:
TBE- Anything that's 3" all the way back will be fine
Diverter Valve- Synapse is best if you stay with stock IC piping. Otherwise Tial is good but you'll have to weld on a flange for it. IMO this a must because the stock DV will leak past 25 psi and you'll prolly need close to 30 psi on a stock turbo for 400whp.
Injectors- FICs are pretty popular for E85. 1050cc or bigger
Fuel Pump- Walbro 255 should suffice but there's lots of debate on this. Research it
Intake and filter- Lots of debate on this as well. Research it.
Boost Controller- Grimmspeed 3 port or a Hallman MBC- Once again everyone has an opinnion
Clutch- Personally I have an ACT XTSS and I love it, but there are many others that are just as good if not better.
Intercooler- ETS, AMS, Buschur, etc- Stick to the name brands and stay away from E-bay on these. At 400whp and around 30psi you'll be pushing the limits of the stock IC so I'd highly reccomend this.
Ported Manifold- MAP, PPI, Buschur are all good from what I've heard.
Old Feb 18, 2012 | 12:33 PM
dangle's Avatar
I'd stay away from a Tial diverter on a stock turbo. On the highway part throttle flutter is murder. I run a synapse and it is hands down a better valve. You definitely have a lot of reading to do on your part selection and reviews are going to vary from person to person. For instance I absolutely hate ACT clutches as both of my evo's have suffered from lock out issues. In my opinion spending more on your clutch has a higher value than cutting that cost with a budget clutch just to afford more engine mods.
Old Feb 18, 2012 | 02:06 PM
Ian0611's Avatar
Yeah I've never used a Tial DV but people have recommended them to me before so that's what I was going off of. Personally, I also have the Synapse and it's hands down the best DV I've used. I've tried several stock metal DVs and a Forge and the drivability on the Synapse is far superior to either of those. Not to mention the fact that it holds any amount of boost you can throw at it.
As far as the clutch goes, there are a number of threads out there that go both ways on the ACTs. Most of the ones where people were complaining about lockout issues were from a few years ago so I wonder if they've changed something since then. I've talked with several guys that are running an ACT with no issues at all. I've had mine for about a year and half now and I love it. It's been great for daily driving and I've put at aleast 20-30 trips down the 1/4 on it and haven't had a single issue with lockout even when I was hot lapping it.
So like Dangle said, do some research and maybe talk to some tuners in your area to see what they reccomend.
Old Feb 18, 2012 | 02:14 PM
tim85851's Avatar
full bolt-ons, cams, injectors. good tune.
Old Feb 18, 2012 | 02:22 PM
Levar's Avatar
Veteran: Army
OK. Let me take a stab at this. Since you already have the stock IX turbo, I am going to assume that you do not have any other modifications for the car (100% stock). I would say this would be the easiest (and cheapest route if you are on a budget). Also assuming that 400whp is your ultimate goal and not +1whp more.
1. Walbro 255lph fuel pump
2. 880-1000cc injectors
3. 3-port boost controller for ECU-controlled boost
4. EBay O2 housing
5. Any vendors lower intercooler pipe
6. crushed stock IX BOV
7. Any vendors turbo back exhaust (with test pipe)
8. 272-duration camshafts
9. tune
Old Feb 18, 2012 | 02:27 PM
thedru13's Avatar
Mods are in sig. I am just shy of 400 on pump. I did not like the synapses valve. The highway flutter made mine undrivable. I am going with the new tial q have heard great things. I daily drive my car and have a long commute. I am really happy with my set up
Guess when I post from my phone they dont show up.
- WORKS Aperture bored throttle body---- WORKS 269 Power Cams ---- WORKS Exhale 76mm thermal coated DP---WORKS Exhale 76mm ABM
- Test Pipe
- Hallman MBC
- Walboro 255 FP---880cc Injectors
- HKS Intake
- Excedy twin disk
- Muse UICP/ETS LICP/ETS 3.5 Intercooler
- Custom Tune by Steve
374.10HP/350.25TQ
Old Feb 18, 2012 | 03:00 PM
06MRV8Killer's Avatar
This is what I have in my 06 IX MR. You dont absolutely have to do the tranny but I would highly recommend it. Matter of fact I wish I still had the 6spd but the built one from Shep
AWD Motorsports Built
Tuned by Diiirk @ AWD
Tephra V7
Dyno Results AWHP 491.88whp 443.88trq @ 31 psi E85 Tune
Power
FP Green HTA 73 84mm Surge Port
Precision 1200 cc injectors
Aeromotive FPR
AMS Fuel Rail
JE Tuff Skirt Pistons
Manley Turbo Tuff Rods
ARP Head Studs
GSC Beehive Valve Springs
Buschur Double Pumper
AMS FMIC
Invidia Turbo Manifold
Invidia Test Pipe
Megan Ported o2 Housing
Fujita UICP and Intake
Injen LICP
HKS Downpipe / wrapped
HKS CF-Ti Exhaust
Hallman Pro MBC
Forge DV
Mishomoto Evo VII Radiator
EGR Block off Plate
Drivetrain
Evo VIII 5spd conversion
Exedy Twin HD
AMS Stainless Steel Clutch Line
AMS Front Motor Mount
Old Feb 19, 2012 | 11:11 AM
JohnBradley's Avatar
2. 1000cc injectors
3. MBC
4. JMFab O2 dumphousing
5. ETS lower intercooler pipe
6. Gus mod stock IX BOV
8. stock cams
9. tune
I have made 430whp on 4 separate cars that way.
Old Feb 19, 2012 | 11:21 AM
Levar's Avatar
Veteran: Army
2. 1000cc injectors
3. MBC
8. stock cams
9. tune
Similar to what I recommended. It is good to see that I am in line with what you have used and proven as a sure way to achieve such a goal.
Old Feb 19, 2012 | 11:41 AM
Whoops forgot to mention IT HAS TO HAVE an intercooler upgrade. The stocker stops flowing between 385-390whp on a Dynojet.
Old Feb 20, 2012 | 01:52 AM
yaba94070's Avatar
02 Housing
Ported Hotside
what kind of gas milage you get??? comparable to stock if you not getting on it???
