What else to do along with clutch/flywheel install
Old Feb 19, 2012 | 08:02 AM
Beebo05's Avatar
So I am getting ready to install a new clutch/flywheel this coming Saturday. I also have a Whiteline Precision Steering Kit to throw in while I'm digging in there. I would like to know what else would be a good idea to do as far as minor upgrades while removing/installing the clutch on a lift. Thanks!
Old Feb 20, 2012 | 03:50 PM
Beebo05's Avatar
No one? I'm throwing in an STM SS clutch line. Anything else?
Old Feb 20, 2012 | 05:26 PM
thedru13's Avatar
remove the restrictor pill from the slave.
Old Feb 20, 2012 | 05:31 PM
Beebo05's Avatar
yea i am not even sure if the previous owner removed it or not but def will if its still their
Old Feb 21, 2012 | 10:47 AM
HyperHoHo1's Avatar
If any of the mounts are bad, you can replace them a lot easier at this point.
Old Feb 21, 2012 | 02:24 PM
Beebo05's Avatar
already did sides and front
Old Feb 21, 2012 | 02:34 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Clutch fork stopper?
New TOB?
Old Feb 21, 2012 | 03:53 PM
Beebo05's Avatar
New TOB?
i read that i wont really need a clutch fork stopper for a single disc and i got an OEM TOB
Old Feb 21, 2012 | 04:03 PM
boostedwrx's Avatar
New flywheel bolts + red loctite
Old Feb 22, 2012 | 03:31 AM
Beebo05's Avatar
got em
Old Feb 22, 2012 | 04:56 PM
ineedboostman's Avatar
Sounds like you got it covered. Did you have anything on your mind.
Old Feb 22, 2012 | 06:36 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
A front swaybar if you need one.
Old Feb 22, 2012 | 06:53 PM
Beebo05's Avatar
hmmm i did consider front sway bar bushings...but its too late to order parts now!!! oops
Old Feb 23, 2012 | 02:11 PM
xXANCHORMONXx's Avatar
OP, I just took out my transmission for a new clutch and to get the transmission rebuilt last night.
http://www.mitsubishiparts.net/catal...tion=1155#2530
The guy whos rebuilding it also recommended to replace the clutch fork and also to get this kit.
Evolution VIII IX CT9A Clutch Release Fork Shaft Kit
My release fork shaft was worn down a bit as well as the clutch fork. Those springs and felt pads are things you should replace as well since your in there.
