starting car have to give it gas!
sup ppl can someone here can help me figure this out.
i bought my evo 8 i started having an idle problem the car would be try to idle really low and almost die i would have to give some gas to keep it from dying. everytime i start the car it dies right after i start it and i will have to start it again & give it gas for it to stay on once the cars is on it idle sh*tty for about a minute or so till it gets to warming up.
MODS:
full exhaust
MODS:
full exhaust
IAC, TPS, or MAF is what it sounds like to me. Sounds like you're car isn't adjusting to the added amount of fuel that it gets on warmup so it's flooding out a little. Clean those 3 parts and see if it helps. Also, check your plugs and plug gap.
This sounds like an IAC for sure. You should try to turn your AC on when its warmed up and just park somewhere, if your cars RPM drops with the AC on, I believe its the IAC. The higher the AC, the more RPM it will drop if its your IAC.
I vote iac valve. Very easy to check. Take off upper ic pipe and its located on throttlebody. On lower part of throttlebody. Check fins on iac valve. If it looks chewed up thats the problem. It was for me. Good luck.
