starting car have to give it gas!
Old Apr 17, 2012 | 11:20 AM
rcheung's Avatar
Also make sure the idle screw is not all the way in. its in the throttle body.
Old Apr 17, 2012 | 11:29 AM
okevolutionVIII's Avatar
If you push in the clutch while coming to a stop and it dies, it's most likely the IAC valve. Just something to try.
Old Apr 17, 2012 | 04:40 PM
barneyb's Avatar
Originally Posted by MrJuls
I definitely have a boost leak.Do you think that could also be the culprit?
On my DSM, I had the vent hose that goes from the end of the valve cover to the intake fall off at the intake nipple and until I found the errant hose I had problems with startup.
Old Apr 17, 2012 | 04:48 PM
evo unknown's Avatar
What is your current mileage?
I have read IACs tend to go every 100k miles. Boost leak could also be an issue.
Old Apr 17, 2012 | 10:45 PM
MrJuls's Avatar
Originally Posted by LGshow19
Does the car have bigger than OEM injectors?
Yes,Precision 780cc.
Old Apr 17, 2012 | 11:17 PM
nightwalker's Avatar
Go see a good repair/tuner shop
Old Apr 18, 2012 | 12:52 AM
ranz's Avatar
did you try fine tuning your idle setting in ecuflash? It might be the case.
Old Apr 18, 2012 | 01:47 AM
MrJuls's Avatar
Yes my tuner did try and tune the idling with ecuflash.
Old Apr 18, 2012 | 05:34 AM
LGshow19's Avatar
If your fuel trims are in check and the BISS is setup correctly try replacing the IAC.
Cranking enrichment is also another thing to try in the ECU. Your tuner should know that if he tried everything already.
Old Apr 18, 2012 | 06:31 AM
MrJuls's Avatar
I'll try set the idling on the BISS,and just wait for the IAC to arrive.Hopefully then it will be sorted.
Old Apr 18, 2012 | 10:32 AM
LGshow19's Avatar
Please update once you have tried and found the solution. Therefore other people can also use this as a troubleshooting guide somewhat.
Old Apr 18, 2012 | 11:44 AM
MrJuls's Avatar
Will do thanks.
