My car randomly started running like crap today.....
Old Mar 2, 2012 | 07:15 AM
rgeier11's Avatar
Check the injectors to see if they are clogged. You can have them off in 20mins. There have been some horrible E85 gunk stories.
Old Mar 2, 2012 | 08:46 AM
Nelson999's Avatar
^ ya I know all about that gunk. That's why I put in the Lucas injector cleaner. Which im thinking is very ironic that this happened right after I put that stuff in my tank.
FX11: my car has 82k miles.
Old Mar 5, 2012 | 02:02 PM
Nelson999's Avatar
Well the spark plugs and injectors looked fine. It started running normal again so I drove it a little bit. About 40 miles with no problems, and now its back to the same problem again. Help!
Old Mar 7, 2012 | 01:02 PM
Nelson999's Avatar
Help!
Old Mar 7, 2012 | 01:33 PM
psphinx81's Avatar
what injectors are you running
Old Mar 7, 2012 | 03:37 PM
Nelson999's Avatar
PTE 1000s
Old Mar 7, 2012 | 03:39 PM
Nelson999's Avatar
Could I have maybe put in too much fuel system cleaner? I poured a whole bottle into one tank of e85...
Old Mar 7, 2012 | 04:04 PM
Chef-j's Avatar
It could be. Ive been heard those cleaner clean up the gunk and it can clog the injectors. But how do i know if its true.
Try use all gas and put fresh e85 see what happens
Old Mar 7, 2012 | 04:42 PM
Nelson999's Avatar
^ thats my first plan before I replace anything
Old Mar 7, 2012 | 05:19 PM
dastallion951's Avatar
if it started running bad like on 3 cylinders pulls your plugs check gap on them and adjust if needed. Also while spark plugs are removed, double check ohm resistance on coils and spark plug wires and coil boots. Make sure all are within spec, and upon resintall put some dye electric grease inside each boot and plug wire to make sure its not shorting out. That would be my first recommendation. If that checks out then do a boost leak test like someone before me posted.
good luck
Old Mar 7, 2012 | 09:55 PM
Nelson999's Avatar
plug gaps looked good, i didnt check the coils yet
its wierd it ran normal yesterday for about 40 miles, then on the way to work this morning it started to cut out a little when i was driving and then was running terrible again until on the way home all of a sudden it started running normal again
Old Mar 8, 2012 | 04:01 AM
psphinx81's Avatar
pull your injectors and check them.. i have a feeling one of your injectors is getting clogged up
Old Mar 8, 2012 | 04:36 AM
ajnasrah20083's Avatar
pull your injectors bro.
Old Mar 8, 2012 | 06:12 AM
FX11's Avatar
Pull your injectors and clean/test them. Also test your coil.
And my friend, you are past due on your timing belt. It needs to be changed at 60k
Make that your next upgrade!
Old Mar 8, 2012 | 09:00 AM
Nelson999's Avatar
I pulled them and didn't see any gunk built up. But im not so sure how to test them?
Also yes a timing belt is my next mod once I fix this
