My car randomly started running like crap today.....
Old Mar 8, 2012 | 09:26 AM
  #31
psphinx81's Avatar
you have to send them out to be checked
Old Mar 8, 2012 | 09:30 AM
  #32
Spec-Ops1's Avatar
It is very possible that it is a coil going bad or the cam position sensor...
  #33
black95tt's Avatar
I had a similar issue. Same symptoms. It was a bad injector.
Old Mar 8, 2012 | 03:20 PM
  #34
Nelson999's Avatar
The tuner said it could very well be the fuel system cleaner messing with the tune and that I should get this tank out abd fill it with fresh e85 before I start replacing anything to see if that fixes it
Old Mar 8, 2012 | 04:42 PM
  #35
nytalonTSi's Avatar
Yeah that stuff you put in the tank does more harm then it's worth, never use it again.
Not known if that is what's causing your problem but that crap can assist the gunk build up.
Old Mar 8, 2012 | 07:33 PM
  #36
Nelson999's Avatar
^ now i know this lol
im just hoping its that stuff making the tune go all wacky, and not a bad injector of bad coil
Old Mar 9, 2012 | 01:26 AM
  #37
MrJuls's Avatar
What about the fuel pump?
Old Mar 9, 2012 | 08:41 AM
  #38
Nelson999's Avatar
Well I ran that whole tank of e85 out last night and put in some fresh e85 so today we will see if it starts running normal.
Old Mar 16, 2012 | 04:39 PM
  #39
m88lty's Avatar
any news so far??? my car has exactly the same symtoms
Old Mar 30, 2012 | 05:46 AM
  #40
jclue's Avatar
Do not want to jack your thread, but I'm having the same problem. Have you figured anything out yet? I only have the problem on the freeway and mine throws a code. Egr insufficient, over-boost and random/multiple misfire. Please post if you've fixed your issue.
Old Mar 30, 2012 | 10:30 AM
  #41
Boosted Tuning's Avatar
EGR insufficient means theres a vac hose that came off on the EGR stuff.
Misfires are most likely due to spark plugs, so check them/change them.
Old Apr 12, 2012 | 07:14 PM
  #42
Nelson999's Avatar
seems like it was just too much injector cleaner in that tank of e85, been problem free now for the last couple weeks
GeorgeP
Northeast Region
May 18, 2017 07:12 PM
Tw3NTy0n3
Feb 17, 2017 08:57 PM
KRS9400
Mar 15, 2016 01:23 PM
Uscbryan
11
Jan 12, 2016 01:55 PM
ryukinevo
Nov 13, 2015 12:00 AM
