Realy need help
Old Mar 1, 2012 | 07:17 PM
im_Zer0's Avatar
Realy need help
So this is what happen, i try to make a DIY COP and cross 2 cables, i think i put the 12v on the ECU position so i figure i fried the ECU cause car dint star any more wen i put the stock coils after that 4 weeks ago and im a pedestrian sense then , there is no local shop that knows much about evos, so i let a local DSM mecanic to take a look and firs he says that it was the ECU, so i got one flash it whit my ROM remove the immobilizer and no luck, change CAM and CRANK sensors and nothing check all fuses change some relays and nothing, now we dont know wat to do, so he says we have to change key code for the new ECU put isn't the immobilizer remove take care of that??? well i hope some one can help me to show us some thing's we might miss to check cause we have no sparks or injector pulse on the new ECU, and on cars original ECU we only have Injector pulse put no spark on coils
TNX
Old Mar 1, 2012 | 07:35 PM
AJCaron12's Avatar
Why don't you start by removing your aftermarket coils first, put the factory setup back and then go from there.
Old Mar 1, 2012 | 07:48 PM
im_Zer0's Avatar
yes that's exactly what i did actually i dint put them after the firs try to start it try to start 2 times and go back to stock ones
Old Mar 1, 2012 | 07:56 PM
TURBO X GSR's Avatar
I'm having a hard time understanding what your problem is.Please use correct punctuation and better spelling. Also pictures are helpful when asking for help.Are there any fuseable links in the wiring that could have fried to protect your ecu?Not trying to dis you or anything just trying to understand your problem.
Old Mar 1, 2012 | 08:05 PM
im_Zer0's Avatar
tnx man and sorry for my bad English, im not sure what pictures i can take to help, don't thing its a fuse i check them 2 times all off them under the hood and dash
Old Mar 2, 2012 | 12:47 PM
There is supposed to be a 80 amp fuseable link on the battery somewhere. Check that.
Old Mar 2, 2012 | 02:01 PM
Could also be at other end of red cable.usually what the cable is hooked to.also this will not look like a regular fuse.to test if bad see if there is any electricity at starter.
Old Mar 2, 2012 | 03:41 PM
im_Zer0's Avatar
if this was the problem will the engine cranks? mine does crank it just don't start, i have injector pulse, gas pump its pumping gas, put i have no spark on sparkplugs
Old Mar 2, 2012 | 04:11 PM
AJCaron12's Avatar
Wait, why did you swap the ECU? And did you put the original one back in?
Old Mar 2, 2012 | 06:32 PM
im_Zer0's Avatar
yes i have two ecu's wit the same flash i was guesing mine fried
Old Mar 2, 2012 | 11:20 PM
Do you have lights ,radio etc?
Old Mar 3, 2012 | 01:50 AM
Mwolf83's Avatar
Do a continuity test on the fuseable link wire. From one end to the other.
Old Mar 3, 2012 | 04:44 AM
LeveeciusEVOIX's Avatar
Check your CPS voltage to make sure its where it needs to be. If your stock packs aren't sending spark either, then it may be a bad CPS, especially if you've already swapped ECU's. Check that fuseable link first though to make sure you didn't fry a wire to your ECU, and if that checks out, check your CPS.
Old Mar 3, 2012 | 09:34 AM
im_Zer0's Avatar
Tnx for the advice ill check that and get back to you
Necrofobic
Aug 1, 2016 08:49 AM
needsboost
25
Jun 28, 2015 02:02 AM
hatesposers
18
Sep 30, 2014 04:41 AM
gsteensland
16
Jul 28, 2012 07:05 PM
dudemeister
Lancer Troubleshooting
Jan 18, 2011 10:51 PM
