Spark plugs causing blow by??? Anyone have this problem before???
Old Mar 7, 2012 | 03:24 PM
Evo8g23's Avatar
I have been battling blow by issues for months now and can not figure out where it is coming from...I have put dye in the oil and even gone under the car while someone revved the **** out of it and nothing...I am on my second catch can setup and this time its dual cans but it still seems to be leaking from somewhere...I meet up with someone for the forums the other day to buy something and during our conversation i told him about the issue....The first thing out of his mouth was "spark plugs"...He had the same issue and went back to stock plugs and it stopped...His tuner told him stock turbo=stock plugs...It kinda made sense the more i thought about it because i didn't have the issue until i did my first oil change and spark plug change...I used the NGK BPR7's i believe...Not 100% but i'm pretty sure
Mod list:
Pretty much full bolt-ons
272 cams
injectors and fuel pump
evo 9 turbo 25-29psi
Soon to be on meth
Old Apr 3, 2012 | 12:58 PM
MR Mitzi's Avatar
I just checked my Spark plugs and I have oil from the top threads down... its not very thick but it was harder to clean of near the bottom.
Oddly the Tips looked to have good burn pattern... Not sure if its Blow By or HeadGasket?!?
Old Apr 3, 2012 | 07:30 PM
cfdfireman1's Avatar
"blow by issues" "dye in the oil" "under the car" "leaking from somewhere"
Do you know what "blow by" is?
Old Apr 4, 2012 | 11:43 AM
Evo8g23's Avatar
Well here...lemme break it down to you what i mean by "blow by"....Oil being blow out from somewhere under boost...whether it be from a gasket, fitting, oil line, oil cap, ect...That's what i consider it...I'm sure you have a different opinion...I have tried the dye...No luck
Old Apr 5, 2012 | 06:34 AM
I don't think I have any "opinion" on the definition. It's already been defined and that's that. Now if you have an "oil leak" that's a different story. If said "blow by" is indeed causing your oil leak it will be around the dip stick or trough the valve cover vents.
Blow-by
The Mixture of fuel-air which is lost past the piston rings and causes fumes that form acid and Sludge in the crankcase and smoking from the oil filer hole. Generally there is a loss of engine power. Most are removed through the PCV system.
Old Apr 5, 2012 | 06:37 AM
And spark plugs don't cause "blow by" unless they punch a hole in a piston.
Old Apr 5, 2012 | 09:42 AM
Evo8g23's Avatar
Thanks for clearing that up for me
Old Apr 5, 2012 | 09:50 AM
barneyb's Avatar
Still running a PCV valve?
Old Apr 5, 2012 | 11:24 AM
Sorry, I failed to mention you can get "blow by" like symptoms on a turbo charged car from a PCV valve that's not sealing correctly.
Old Apr 5, 2012 | 12:00 PM
Evo8g23's Avatar
Yes with dual catch cans...I had a single Buschur catch can that drained back into the pan but once it started getting cold here in Connecticut i started getting moisture in my oil...I have to say it did help tho...I may swap the PCV catch can out and put the Buschur one back on because it has a breather filter but instead of draining it back to the pan i will drain in to the ground...Or i could always just run a pipe straight from the PCV to the ground
Old Apr 5, 2012 | 12:20 PM
Vivid Racing's Avatar
Have you cleaned or replaced the PCV valve and made sure all of your lines are clear? Sounds like that could definitely be the issue.
Old Apr 5, 2012 | 01:47 PM
Evo8g23's Avatar
Yup i replaced the PCV valve with the aluminum nipple that was provided with the Buschur kit and all new lines going to my catch can and back to the intake manifold with 2 check valves...But like i said when i had the Buschur can on there with the breather on top it worked quite well but i got moisture in my oil...I will probably go back to that but not drain it back into the pan...I think its my best bet
Old Apr 5, 2012 | 02:29 PM
bubba17's Avatar
check the turbo return line going into the pan, i had major blow by come to find out it blew out the gasket on the oil pan and had a slight leak on decell but poored on acceleration
Emperor 4g63
16
Jun 8, 2017 12:50 PM
inshallah
Jul 5, 2016 07:52 AM
SeahawksOilers
Apr 26, 2014 12:40 PM
chronotrip21
Lancer Troubleshooting
Jan 4, 2013 12:18 AM
taylorgang
Oct 3, 2011 06:21 PM
