s3's with stock valves/pistons
Old Mar 9, 2012 | 12:40 PM
silverofs's Avatar
i've searched but i couldnt find anything to confirm if you can run s3's or kelford 280's with stock pistons & valves ?? (9 mivec motor)
any help or experience would be great thanks.
Old Mar 9, 2012 | 12:42 PM
CAD EVO's Avatar
I'm running S2's and was told to upgrade my valve springs. I can imagine you would also need upgraded valve springs for the higher lift S3's.
Old Mar 9, 2012 | 01:39 PM
95gst16g's Avatar
Yeah you really shouldn't even run the 2's or even kelford 272's with stock springs...
Old Mar 9, 2012 | 01:42 PM
Svendiesel's Avatar
Aaron mentioned to a friend of mine just the other day that S2's shouldnt be revved past 7200 on stock valve springs.
S3's would raep house on everything.
Old Mar 9, 2012 | 01:46 PM
silverofs's Avatar
i said nothing about stock springs.
with upgraded springs has anyone ran stock valves & pistons with s3's ??
Old Mar 9, 2012 | 01:52 PM
doghouse's Avatar
are you referring to the clearance "valve touching piston" ?
Old Mar 9, 2012 | 02:05 PM
silverofs's Avatar
correct
Old Mar 9, 2012 | 02:21 PM
GGevo921's Avatar
To the OP i just asked this very question last night. Here are some of the responses i have got. take a look. https://www.evolutionm.net/forums/ev...eded-asap.html
Old Mar 9, 2012 | 02:22 PM
EvoJoeIX's Avatar
S3's wont make valves hit pistons
Old Mar 9, 2012 | 02:24 PM
GGevo921's Avatar
Not trying to call you out but do you have proof of this. Im really looking for this info and need to know. Any proof or research you could show be greatly appreciated. So far from what ive gathered there wont be enough of a clearance but then again i have oversize valves.
Old Mar 9, 2012 | 02:31 PM
EvoJoeIX's Avatar
Heres one car that does it, i know of a few others also
http://www.youtube.com/watch?v=mTOTgAhS-Q8&feature=fvst
Old Mar 9, 2012 | 02:35 PM
GGevo921's Avatar
Do you know if they had to change anything to make them work?
Old Mar 9, 2012 | 02:38 PM
EvoJoeIX's Avatar
fixed link
what would you change? it says right in the description, stock motor. if thats not enough proof, i dont know what to tell you. s3's work on stock motor
the only difference in the s3 from the s2 is .2mm higher lift on the intake side. its not a huge difference in peak lift
Old Mar 9, 2012 | 02:47 PM
GGevo921's Avatar
fixed link
Not so much worried about lift as duration when the valve is chasing the piston. Im also running oversize valves. had a couple people who do head porting question it thats why im just trying to be 100% sure thats all. Thank you for the input! greatly appreciated!
Old Mar 9, 2012 | 02:51 PM
EvoJoeIX's Avatar
so if your running oversized valves, did you have your whole head built?
if so, im gonna assume it was decked. now at this point, it depends how much was taken off the head
