2.3 owners, need your suggestions - rod to block clearence
Old Mar 16, 2012 | 11:48 AM
stunt2's Avatar
Exclamation 2.3 owners, need your suggestions - rod to block clearence
4G64 100mm crank/Manley H beam rods. do every 2.3 stroker with thicker rods require notching the block like in this vid of E9 engine ? or it depends on model (E4 if it matters)
http://www.youtube.com/watch?v=oeBzgSFGGs0
Old Mar 16, 2012 | 11:52 AM
okevolutionVIII's Avatar
It depends, you should always check. Mine with Eagle H-beams needed no clearance.
Old Mar 16, 2012 | 12:47 PM
Piro Fyre's Avatar
Every block is different. Mine needed notching on one of the cylinders but the rest of them were fine. Always good to get it checked by the machine shop.
Old Mar 16, 2012 | 01:06 PM
stunt2's Avatar
so as I guess it depends on just individual block casting, not model or year dependent
any more inputs are welcome, the statistics is kinda interesting
Old Mar 16, 2012 | 05:03 PM
justincase's Avatar
yep i have carrillo H beam pro's in mine and they require a 'clearance channel' so to speak. Pretty common done on V8u's when changing to a stroker set up.
I know some people here in Australia said I'd never be able to fit the H beam pro's in a stroker.
Ask Lucas Gudagni and Chad Block, they have done and do, it works.
I never had a problem with any block that has had this done either.
Old Mar 16, 2012 | 09:19 PM
ExViTermini's Avatar
I've built one and assembled two other 2.3 shortblocks with the Manley h-beams, and none required clearancing. The i beams on the other hand will need some block massaging.
R/TErnie
26
Sep 23, 2017 04:42 PM
SBR INC
Nov 26, 2016 07:39 AM
CO_VR4
52
Feb 8, 2012 01:03 PM
SBR INC
22
Jul 27, 2010 11:33 AM
Strictly Modified
12
Feb 20, 2009 11:20 AM
