ACT 6 pucks ultimate holding power ?
Old Mar 16, 2012 | 03:09 PM
600+hp's Avatar
Any real life experience out there on how much a 6 pucks with an HD pressure plate can hold ? What's your highest WTQ.
I'm currently at 560whp/505wtq with 33-34psi from the HTA 3076. We back down a bit on the TQ knowing the clutch advertised limit.
I'd like to push 4-5lbs more to about 38lbs boost but doubt if the clutch will hold the TQ which then will likely get past 550wtq.
ACT website list it at 650 TQ with the HD pressure plate, I assume flywheel which make it about 520-530 WTQ.
The street disc with the HD pressure plate is rated at 510 TQ but I was able to use it with my 50 trim setup making 470ish WHP/ 450 WTQ. Assuming 20% drivetrain lost that's about 40wtq more than the advertised #s.
