Castrol 10w60 for build engine?
Old Mar 20, 2012 | 01:15 PM
Nickolaus's Avatar
Hello all! As topic, is the castrol 10w60 a good oil for a built evo ix engine?
Thankyou //Nickolaus
Old Mar 20, 2012 | 01:55 PM
_david_'s Avatar
I use motul 300v and I recommend a synthetic ester based oil (motul 300v, redline, millers, silkolene,...)
Old Mar 20, 2012 | 02:09 PM
Nickolaus's Avatar
i have motul 300v now but i dont wont to use it again, due to difficulty to get!
But the 10w60 castrol is also fully synthetic.
My question was really if the 10w60 is to thick?
Old Mar 20, 2012 | 02:21 PM
westheevokid's Avatar
id say thats pretty thick, i would not run anything over 20w50.
Old Mar 20, 2012 | 02:31 PM
alleggerita's Avatar
The 10/60 Castrol works as a 60 weight at high temp but really is not thick at all and makes good power on the dyno. Price is no worse than some other high end synthetics - BMW dealer is just about the only place to get it in North America. I use it in one car (normally aspirated) but use 5-40 Rotella on the Evo.
Friend in Europe uses it on all their race cars and personal cars including turbo. Much less wear on the race car engines than previous oils they used. When it burns it almost smells like bean oil, eg old Castrol R if anyone remembers that.
Personally, I'd have no hesitation running it in a built Evo and many of the guys in Europe on lancerrregister seem to be running it. Probably unneccessary/overkill but BMW specc'd it for their M series engines after they were having bearing problems and this seems to have been solved the issue.
BTW, here's a link on 10/60 discussion:http://lancerregister.com/showthread.php?t=244716
Old Mar 20, 2012 | 02:32 PM
_david_'s Avatar
I think that for sweden winter is pretty thick
do you have oil temperature gauge?
Old Mar 20, 2012 | 02:54 PM
Nickolaus's Avatar
I only drive the car summertime. so that is why i want to run 10w60
Yes i do have a oil gauge
Old Mar 20, 2012 | 03:02 PM
_david_'s Avatar
what is the max oil temperature when you run your car?
what is the temperature in summertime?
Old Mar 20, 2012 | 03:21 PM
Nickolaus's Avatar
i dont know the maxium temp, i will go to tuning the 2 april, then i will start driving, around 20 celcius
Old Mar 20, 2012 | 03:35 PM
_david_'s Avatar
If your oil engine doesn't exceed 115º/120ºC I would choose a -w50 oil
EVOEvolved
Jan 6, 2022 04:31 AM
elim0
Jun 23, 2015 06:07 PM
Jag14916
May 7, 2012 11:33 AM
Nickolaus
25
Feb 20, 2012 06:03 AM
kouzman
14
Dec 20, 2009 12:42 PM
