HTA Green transient response
Old Mar 26, 2012 | 11:37 AM
RSMike's Avatar
There will be some form of accel enrichment in the ECU settings, try to find it.
Old Mar 26, 2012 | 10:20 PM
APEX'iEvoIV's Avatar
yes it has accel enrich, all that is set, it seems fine now after adjusting the preload a bit
Old Mar 27, 2012 | 08:29 AM
kyoo's Avatar
can you post a before and after? and update the OP?
Old Mar 27, 2012 | 11:33 PM
I checked it and it had approx 1/4 hole preload, I adjusted it to 1/2 hole and it now goes to ~22psi with no ebc.
The data logs look much better .6 in 3rd to hit full boost and it also peaks in 1st now as opposed to just rising with rpms.
As per that post, the results are more visable in my data logs which I can not put up a pic of, the last vdr I did was a few psi lower than that original one so it doesn't really compare. My rear diff has cried enough how ever so it is parked for the time being
mrfred
Apr 26, 2016 05:05 AM
David Buschur
Sep 6, 2015 09:27 PM
mrfred
Dec 31, 2014 08:27 PM
Freddy302
Feb 8, 2010 02:46 PM
RallySport Direct
Oct 31, 2008 05:07 PM
