Old Mar 24, 2012 | 11:23 AM
breeze17's Avatar
so my CEL is on and i took it to m mechanic. he ran a diagnostic and saID CATALYTIC CONVERTER was bad. should i just have him remove till i get a new TBE or keep it on there. whenever i rev my engine it makes a rattlin noise and its annoyin as S***. advice much needed
Old Mar 24, 2012 | 10:45 PM
cmspaz's Avatar
Gut the cat, flash Tephra v7 to the ECU, turn on the rear o2 simulator.
Old Mar 25, 2012 | 04:22 PM
breeze17's Avatar
ive never f***** w/ loggin an all that. im gettin ready to buy tactrix n the software. is this somethin easy to learn
Old Mar 27, 2012 | 01:13 PM
breeze17's Avatar
can I completely remove the cat without any logging or do I still have to have it but just gut the inside of the cat
Old Mar 27, 2012 | 10:11 PM
breeze17's Avatar
bump
Old Mar 28, 2012 | 09:05 AM
dastallion951's Avatar
you dont need to gut the cat man, you already through a code, just buy a test pipe, and buy what is called a spark plug anti fouler. Search on here for those words get the part#. Go to the parts store buy it, you screw your rear 02 sensor into it, and the other end goes into your exhaust pipe. Clear your check engine light code, and it shouldnt turn back on. Simple
Good luck
Old Mar 28, 2012 | 09:35 AM
Chef-j's Avatar
Sounds like its bust inside. Worst than just some damage cat. Air will not flow smooth at all, should replace it soon before it hurt the engine.
Old Apr 6, 2012 | 09:36 PM
breeze17's Avatar
how do i clear my CEL code, by just unpluggin my negative wire on my battery?
Old Apr 7, 2012 | 05:06 PM
AJCaron12's Avatar
Yeah you could do that, or ask someone with a scan tool to clear the code. Autozone has a code reader to clear codes if you want.
Old Apr 7, 2012 | 08:56 PM
420a-t's Avatar
Awesome thread title man
Old Apr 18, 2012 | 06:24 AM
breeze17's Avatar
okay so I installed my test pipe on Friday and did the 02 fouler fix. I was driving out to Everett and my car dies had it towed to my mechanics shop to find out that I kept blowing #18 fuse which has the engine symbol on it. he replaced the fuse and then my car worked fine for about half a day. I couldn't take my car above 4k rpm otherwise my car would die n blow a fuse. eventually it got to the point where I couldn't even start my car without blowing the fuse. anybody kno what the problem could b? I was reading other threads n some ppl think maybe bad crankshaft sensor?! need help n bad. Already p****** off my girl with how much time I spend on evo
Old Apr 18, 2012 | 12:23 PM
cmspaz's Avatar
It shouldn't be a stretch to assume the rear O2 is causing it, considering that's the ONLY thing other than non-electrical exhaust components you should have touched while installing a test pipe.
Try unplugging the sensor and see if the problem goes away, yes it'll throw a light, but it'll be a quick way to diagnose the issue.
Old Apr 18, 2012 | 03:16 PM
breeze17's Avatar
wish i wouldve known this when my car broke down in the middle of the night. why would that sensor cause that problem is my question
Old Apr 18, 2012 | 04:03 PM
Blue91lx's Avatar
Quite the riveting title you have here good sir.
slowsrt4:(
E85 / Ethanol
13
Aug 30, 2014 06:50 AM
PCToolsWiki
May 26, 2012 07:00 PM
slvrRalliart cf
Lancer Engine Tech
Feb 26, 2007 05:09 PM
kapolani
Jul 17, 2005 10:29 AM
