Buschur...you just got a new customer....
Old Jan 20, 2004 | 10:53 PM
CweSt eVo's Avatar
Im converted from the expensive jdm power aftermarket to the buschur racing aftermarket after seeing and hearing about the power your cars are putting out......I already have a jic titanium exhaust...but am looking to get everything else that you make for the evo done...starting with your downpipe and test pipe....will it bolt up to my jic exhaust?....
Old Jan 20, 2004 | 11:29 PM
evo81's Avatar
same question but i just got a greddy ti cat back and would like to know if the BR downpipe and test/highcat flow will work with it?would like to be a new BR customer also.
Old Jan 21, 2004 | 01:18 AM
Fourdoor's Avatar
You both would need to either add a flange to the BR setup or weld it to the cat back you already have. One of the things that makes Dave's systems light is the lack of flanges, they are a slip fit design.
Keith
Old Jan 21, 2004 | 09:13 AM
David Buschur's Avatar
That's right fourdoor.
If the systems you have are full 3" systems you can simply cut their reducer and flange off and slip fit ours over it and clamp it.
The other option is to weld a flange to our system but more than likely that is going to leave you with the reducer that is at the front of your catback now.
David Buschur
www.buschurracing.com
.DoT.
May 28, 2016 05:48 PM
ZeRoMaX
Oct 6, 2015 01:10 PM
ms32evoixmr
10
Aug 14, 2015 10:51 AM
201Motorsports
14
Oct 23, 2007 06:38 AM
Paul2x
22
Apr 20, 2005 04:59 AM
