should boost taper this much
Old Mar 30, 2012 | 10:35 AM
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by AlwaysinBoost
If you aren't able to hold pressure its cause there is a leak somewhere. A system with no leaks will hold pressure fine, but still slowly bleed off. When I say slowly I mean like 2psi a minute.
I just helped a friend leak test his car for the first time the other day. He has a MASSIVE leak somewhere in the motor and its pressurizing the valve cover. I/we suspect the valve seals as the problem, but the weird part is the car doesn't burn/lose oil...
i have done boost leak checks on my car and i have always had alot of air coming out of the valve cover (port that goes to the intake tube). i usually have to plug the line to get it to hold. when my cams were installed i had replaced my valvesprings so they pressurized each chamber and they all held great no leaks.
Originally Posted by honda-guy
^ looks pretty flat with bbk up till 6k rpm then it starts to drop.
I have a track event this weekend and don't have time to mess with the EBC now, but ill throw it on next week and compare.
the BBK is great at holding that boost. im going to retune at 28 and im hoping it will have minimal taper as well if it can hold 25psi by redline i'll be stoked
Old Mar 30, 2012 | 09:09 PM
sparky's Avatar
I don't see how you can hook an MBC up incorrectly, there are only two lines to connect..... I was simply pointing out the fact that an MBC will taper up top where an EBC, if setup correctly.... Dont try and turn this into a MBC vs EBC debate, that is not what the thread is about.
When I mentioned MBC "set-up", I was not referring merely to the simplistic task of connecting the two vacuum hoses to the ports on the MBC body. I stated MBC set-up, not merely the hooking-up of two vacuum hoses. FYI, just as there is a right way and a wrong way to "set-up" an EBC, likewise there is a right way and a wrong way to set-up an MBC.
By setting up an MBC properly I was alluding to certain related adjustments that go beyond the simple process of connecting the hoses and the equally simple act of turning the adjustment knob. There is considerably more to it than that. Just because you hooked up the hoses and turned the knob, doesn't mean that you set it up properly. You sure won't get the best results doing it your way. Your analysis oversimplifies a problem(boost taper) which could, in fact, very well be caused by several factors other than and independent of the choice, installation and employment of any one particular type of boost control device.
Again, IMO, you may be steering the OP off course by suggesting with such certainty that his MBC is the cause of his turbo's boost taper issues. Agreed, under certain circumstances the MBC may sometimes be among the possible contributing factors in some boost taper scenarios. But, it is not, as you seem to be implying, the ONLY possible cause of boost taper issues under any and all circumstances.
Furthermore, I don't agree with your advice that simply installing an EBC, will a priori, cure his boost taper issue. The EBC is not by any means a universal cure-all for this type of boost taper issue. Ergo, the MBC is not the only possible, nor even the most likely root cause of his boost taper. I think that you are, at best, ill informed. But, of course, you are entitled to your own opinion.
Actually, I was not arguing about MBC's vs. EBC's. I don't champion MBC's at all. I just don't happen to agree with your generalizations that a MBC will always cause boost taper up top and that alternately, the EBC is a miracle cure for the MBC's supposed deficiencies. I am not really arguing. I simply choose to differ with you on this topic. I happen to be of the opinion that the OP's issues may not be related to his choice of boost control device at all.
Finally, EvoM is an open discussion forum. Divergent opinion is encouraged, as long as it does not lead off topic, or become disrespectful.
Old Aug 8, 2012 | 07:32 PM
connor4200's Avatar
Originally Posted by 10isace
I can definitely hear a leak when I open the oil cap. I'll try a boost leak test when I take off the valve cover. I'm not losing much oil either (1/4 quart between oil changes).
make sure to keep the oil cap off when boost leak testing so you dont pressurize the crankcase
Old Aug 9, 2012 | 01:58 AM
RSMike's Avatar
Does your TD06 exhaust housing have a larger than stock wastegate flap?
If so, this could be the problem.
EBC will help, you can reduce the amount of boost that the wastegate actuator is seeing - closing the flapper which increases boost.
Cheers, Mike
Old Aug 9, 2012 | 02:40 AM
honda-guy's Avatar
Yes, the td06 does have larger than stock wastegate flapper.
I have atp gtx3076r now and so far boost can hold flat at 25 psi till redline on same boost controller.
powerman00
Nov 27, 2015 05:54 AM
bnice01
91
Apr 29, 2014 06:37 AM
DSMolition
10
Nov 21, 2013 10:58 AM
CDrinkH2O
47
Oct 17, 2012 08:13 PM
firebad
Jan 18, 2010 01:57 PM
