boost is falling way off, please help!!!
ok so i was doing some WOT pulls and i could tell something was wrong i boost 28psi then its falls all the way back down to 18-19psi. i did a boost leak test and its all good, i dont know whats going on.
stock turbo and wasgate
272 cams
hardpipe kit
hks intake
3in TB exhaust
deachwerks 880s fuel injectors
please help
272 cams
hardpipe kit
hks intake
3in TB exhaust
please help
It will always be 18-19 at 8k on a stock VIII turbo. WGDC means WasteGate Duty Cycle which is a percentage that tells you how much you are requesting.
For instance 100% means EVERYTHING it can do, think the boost line off. 0% is the least it can do or straight wastegate line.
I would replace all vacuum lines first. Next suspicion would be injector seals or throttle body shaft seal. It could also be a leak on the wastegate. Ensure there are no cracks on the hotside of the turbo, particularly where the wastegate is separated from where the o2 housing connects. It could also just be the turbo if you have 100k on the car. Pretty sure stock turbos are not ball bearing. Trying to get the stock turbo to hold that much boost over 8,000 rpm is asking a lot. Even my 35R tapers by about 4psi or so above 8k rpms.
you guys think my stock block can hold that? compression is 150/160/160/160 +or- 2 psi because it is an analog tester.
my goal is 400whp, i read to try adn keep the tq under 400 and i should be fine.. what you guys think? remember the car has over 100k and im making 298whp and 255tq and that was on a mustang dyno. and i cant get e85 at my location.
Couldn't find any cracks, replaced vacuum lines and still not fixed. Bought a used evo turbo and a MAP wastegate. I'm hoping it's just and old turbo and wastegate issue. Have any of you tried the spring trick for the wastegate?
