Manley pistons vs Wiseco Pistons
Old Apr 12, 2012 | 03:21 AM
novik7's Avatar
Which are better
Old Apr 12, 2012 | 04:12 AM
GSR ONE's Avatar
Wiseco for sure. There 1400HD are quality. I prefer JE (same company), just my preference.
Old Apr 12, 2012 | 04:19 AM
PsychDr. HN$'s Avatar
I cant say which is better but I have Wiseco 1400's
Old Apr 12, 2012 | 08:19 AM
grim~'s Avatar
manley rods+weisco hd pistons=win.
Old Apr 12, 2012 | 08:30 AM
Sirnixalot's Avatar
^ I am running Wiseco HD's and Manley H beams
Old Apr 12, 2012 | 08:54 AM
03whitegsr's Avatar
Wiseco's tend to be pretty heavy though.
As for shelf-stock, manley seems to have some pretty good options on compression ratio and compression height to work in long rod/stroker setups.
Old Apr 12, 2012 | 09:14 AM
okevolutionVIII's Avatar
If I had a setup I didn't want to touch/replace again, it would be Wiseco HDs and Manley Turbo Tuff rods.
Old Apr 12, 2012 | 09:29 AM
LRM1981's Avatar
Wiseco HD and MAP ultimate duty rods, FTW!
Old Apr 12, 2012 | 09:41 AM
Blue91lx's Avatar
What he said.
Old Apr 13, 2012 | 10:33 AM
novik7's Avatar
Sounds good, ive been debating on full manley rotating assembly to build a 2.2 or using manley turbo tuff crank 93mm, bc rods, and wiseco pistons to make optimum power
Old Nov 14, 2012 | 09:07 AM
sovietEVO's Avatar
definitely wiseco pistons. I say manley rods though. Manleys pistons have a faughlty design so literally every set that was used recently in their new design ended up cracking and warping. The wiseco pistons design is a lot thicker with bigger wrist pins and are used by a lot of big name tuners in their high hp cars. Although manley was confronted about this problem and is completely redesigning their piston which should be released soon. I myself had this issue with manley and switched to the wiseco hd pistons
Old Nov 14, 2012 | 10:35 AM
chu's Avatar
chu
Same here on my recent 2.3L build. Everyone who I respect recommended Wiseco. CP is also a very good choice.
Old Nov 14, 2012 | 02:11 PM
n2oiroc's Avatar
custom arias ftw!
Old Nov 17, 2012 | 03:49 PM
the evo kid's Avatar
wiseco 1400hd well worth the money
Old Nov 17, 2012 | 04:26 PM
JohnBradley's Avatar
Any strutted piston (i.e Wiseco 1400HD) is better than a full circle at keeping skirt collapse away. I have seen Manley pistons crack in the skirt and bend the light duty wrist pins (.150 wall I believe). The Wiseco arent that much heavier but even then we take off the shelf pistons, put them in Jeff's car, and run low 8's. The 0.225 pin (JE offers a .250) and the pistons inherently quiet nature compared to other pistons at similar PTW make them my choice.
